Building Wolf Treasure [Tesoro Lobo]
  • Building Wolf Treasure [Tesoro Lobo]
    I don't know much about electronics, but I'll give it a try.
    I already have the PCB assembled with all the components. I hope Geotech friends help me in this project. I will greatly appreciate your help.
    Wolf Treasure ???
    more information needed
      Ruben2000, maybe you meant "Tesoro Lobo". "Wolf Treasure" would be English translation for it.
        If that's what I mean, the translation has failed.
          I assembled my PCB with repurposed components and made the single-sided PCB.
            I think that in order for anyone to assist you in this project that you will need to share the schematic so that we can see the circuit.
            Cheers
              William Lahr's schematic. there was not another.
                Disculpen amigos, tuve un problema por eso no pude publicar el esquema en el que estoy trabajando.
                Aqu? lo publico: [ADJUNTE] 55791 [/ ADJUNTE]
                  I also publish my single sided PCB for those who want to build it. I copied it from Shevakotic; I just made it some changes. I also leave the file in Black and White.
                    hockey, but why you do not want to continue threads of the forum? for example this one
                    https://www.geotech1.com/forums/show...soro-Lobo-news
                      Because I want to learn as I build my own PCB and take measurements to publish and so that several can help me; As I said before, I don't know much about electronics.
                      I published the measurements of my homemade coil for Tesoro Lobo in the Russian forum md4u.ru and nobody answered until now with my query and if I am still here in a Lobo thread, the same thing will also happen.
                      Also I want others to benefit the same as me.
                        Here I post the potentiometers and switches.Click image for larger version
Name:	Potentiometers and switches.png
                          A query; I don't have the BF245s but I have 2N3819, NTE312, 2N4393, 2N4392.
                          Which of them would be the best?
                            Soon I will post photos of my PCB; although I'm not good at welding
                              Hi friends!!
                              Here I post some photos of my PCB with the components.Click image for larger version
ID:	361775Click image for larger version
ID:	361776Click image for larger version
ID:	361777Click image for larger version
ID:	361778Click image for larger version
