Building Wolf Treasure [Tesoro Lobo]
  • The wolf trax, lobo super traq and tesoro dingo are essentially the same. I wish you success. Use the pc soundcard oscilloscope. At least you can dive a little deeper.
    • Thanks. Will let you know if I get it sorted.
      • Just one more question if I may? In your first post you mentioned there should be a -6v rail but I cannot find any components with a minus volt. Do you know what which component/regulator is the source? The main voltage regulator used here is the 2970T +8v and that is working fine.
