KROT 1 equivalente mc34119
  • KROT 1 equivalente mc34119
    Hello, I'm looking for an alternative to the mc 34119, hard to find here in Brazil. I'm building the KROT 1 and I can't get the CI. output TX.grace?o;circuit with alternate circuit
    from a forum i keep
    Вот УНЧ для замены MC34119: LM4818, LM4819, LM4862, LM4864, LM4882...KA8602B
      thanks
        Does anyone have a wiring diagram with another IC to replace the mc34119 in the Krot 1 detector
          A quick search on the free market
          https://produto.mercadolivre.com.br/...ifier-dip8-_JM
            https://best.aliexpress.com/
              hi all friends a was make this krot 2-3 xm the problem is it dosent stable
                LM4818 should work as pin compatible replacement. Just drop it into the circuit.
                  OK, I'll test it if it works, I'll post the result. Hugs to my friends. Thanks
                    thinking you must do especial stand for tuning of a coil. this will be analog schematic with TX generator and RX pre amp.
                    you must use oscilloscope.
