Compadre Schematics
  • #31
    I don't know the circuit well enough yet, but I wonder if the motion mode depends basically on some kind of time constant somewhere (capacitor, etc.). Rather than make it totally static, maybe could switch to a really long time constant (like adding a capacitor in parallel with a switch) that would approximate a static mode for 10 to 20 seconds or so. Seems like that might be easier and avoid instabilities and drift problems. Just a wild idea.
    are the two 0.47uF caps that make it motion... you can change them to something different but the more the cap the more the time it takes to retune. You can try using bigger using some double-switch to see what happens.
    Kind regards,
    • #32
      Kind regards,
      Thanks, it would be interesting to experiment with that for pinpointing.
      • #33
        I don't know about warranty (lifetime !) lost if screws are removed... ops... so consider well the pros and cons before screwing it...
        4016 are integrated transmission gates (bilateral switches) much like fets operate; you can replace with 4066 if you need.
        When disabled you have hi-impedance between port's leads... when enabled you got something from 50-200 ohm depending on device/brand/family.
        I'm not sure... but think original Compadre has real fets there and you have to replace with transmission gates.
        The TLC2262 is a modification too I think: they are present in bandidoII and the scope is wasting less power on op. amps. though getting very good noise level (lower than with LF ic).
        Look at the Tesoro's section you'll find a thread about bandidoII where I explained (months ago) the various blocks etc
        Kind regards,
        Max:
        Which is the more sophisticated or capable detector: the Bandido II or the Compadre (newest)?
        • #34
          Max:
          between the two bandidoII is sure a winner... at least the one I have made that can do impossible stuff I think for an original one, it's heavy modded with custom components to get the best... stability, sensitivity and good (not perfect) disc. But I think also original bandidoII will beat compadre hands down.
          I'm sure Compadre simply cannot compete with bandidoII on stability... cause of components: they are truly lower noise in bandidoII... don't know if newer/last versions of compadre has them too or similar stuff, but I think not cause price is always less.
          Also, bandidoII has many operation modes and setting... compadre hasn't, cause it's an essential MD... good but not as good as others from same brand.
          So I think bandidoII is winner cause guys at Tesoro want this way and used finest solutions and options on it.
          Kind regards,
          • #35
            Kind regards,
            Hi Max, what do you mean by the "Tesoro section", I'm not seeing that
            • #36
              you had to dig it... ok here is the link :
              https://www.geotech1.com/thuntings/s...ad.php?t=12738
              Sure the stuff is valid for bandidoII but with little variations (you can compare schematics easy I think) the same you can apply to all old tesoro's VLFs that are pretty similar MDs.
              If there are problems understanding let me know... I will try to explain.
              Kind regards,
              • #37
                Kind regards,
                Thanks Max, you're a gem!
                • #38
                  I opened up my new Compadre (with 5.75" coil) control box to see if I could tune it "hotter", that is, more depth at the risk of more noise.
                  I only saw three small trim pots. They only turned one or two turns at the most. They were each set somewhere in the middle of their range. I turned each one max clockwise and then max counterclockwise.
                  I did not see any real difference in depth with my indoors air tests. I detect american coins at about 5 inches (12.7 cm) max; pennies, dimes, and quarters (clad) all register about the same depth, the dime a little less.
                  When I turned each pot to its max and min value, never did the detector go unstable or chirp or anything -- it just remained silent.
                  I'm pretty disappointed in the depth. I don't expect fancy features for such a low cost detector, but I was still hoping it could get a little more depth in all metal mode; I was really hoping there would be a pot that could make it more sensitive, but the trimmers don't seem to change much.
                  Has anyone (Steve in MS?) done any tests on the latest Compadre and found a way to tune it more sensitive (without modifications)? If so, what did you find?
                  BTW: at least the descriminator does work pretty well anyway in air.
                  • #39
                    you made it the wrong way I think... but now that the MD is already untuned (you probably changed the geb and disc presets used in factory tuning) you can also experiment more with it...
                    Sure you cannot get more depth by just changing that trimpots positions... pretty easy and already explained: you have just 10Vpp amplitude at TX coil... and coil is also small so depth will be always as before this way.
                    It's like when you try to mod your motorcycle... and start replacing the carburetor filter... to get what ??? 0.01 HP more ? Maybe 0.01mph more ???
                    No, no man... you need more and more HPs to go deeper into soil...
                    A good try would be modding the osc supply , raising to (at least) +8V... but , as always, do at your own risk (like the pot changes of above).
                    You could also avoid messing the circuit and just make e.g. a larger coil for it... but you'd better have a scope handy to make one good way... cause few people really tune coils right way using just multimeters.
                    The Compadre could take advantage of existing recipes (look e.g. at TGS thread) and homemade coils designs... you could probably use Ivconic's recipe without mods on Compadre : it's a large (27cm diameter) DD type coil for uMax series... I've made many and works cool on both TGS and bandidoII... recipe it's also easy
                    100turns for TX , 105 for RX, wire is 30AWG
                    Call this : soft tuning!
                    Best regards,
                    • #40
                      Thanks Max once again, these are great ideas...
                      I hopefully restored the pot settings then turned just the one that Steve confirmed for me (at top of PCB as you hold the detector) counterclockwise, and I did get some significant benefit, so very grateful for that to begin with, I was a little sour not getting the "Max" () out of my detector...
                      I'm very interested in a larger coil and what kind of connector you would wire into the cable that would make clean connections, since I'd have to cut the cable on the Compadre and install a connector. If a large coil would help me go deeper at the beach, that would be exciting, although I have to think twice about losing that Tesoro warranty ...
                      I do have an oscilloscope and some circuit background (although I haven't etched CBs so far) so I'm interested in the procedures involved with making the coil.
                      So... thanks again for the ideas and references.
                      By the way, do any of the circuits, such as the Bandido II or Golden Sabre work on solderless breadboards, or do you need to etch a PCB for them to work at all?
                      Thanks,
                      Best regards,
                      • #41
                        Maybe too many questions, but always appreciated...
                        A question about Ground Balance and Disc trim pots...
                        What measurement would you make to confirm they were set best, or is it just a magic setting that Tesoro uses based on experience with soils, etc?
                        If you build your own Amigo, Bandido, etc.... how would you trim those pots without Tesoro's data?
                        Best regards,
                        • #42
                          Thanks,
                          I never tryed mounting whole schematic on breadboard... too complex and lot of wires required. I think that circuits like bandidoII and similar will work too but with lot of troubles related to e.g. self oscillations and cross-talks due to cross of wires.
                          Sure you can make one of them breadboarding stuff... but results will be not like when using a real PCB. Think e.g. at comparators you can get them work easy on breadboards... but then the noise there will make them saturate very easy , in a large amplification chain.
                          Some parts are less critical e.g. oscillator , frequency divider and sampling gates and also audio stage... but the real problems will start at preamp and next amplifiers till comparators where problems you'll see as very fast self-oscillations and much of instability.
                          Kind regards,
                          • #43
                            good questions. At first I was a little in troubles with them but then find that a member (goodrat) posted about diagrams of bandidoII (well, actually, if I remember well goodrat owns a modified compadre that acts like a bandido)... but also other informations I get from e.g. Qiaozhi and other members.
                            You can find e.g. my tuning data for TGS looking at page #57 of TGS thread: I posted a lot of pictures of my readings of phase etc for plenty of test points I made on my TGS.
                            You can find goodrat's diagrams too and compare them: you'll notice tesoro's disc and geb setting are pretty close from one detector to another. The big change is always related to disc interval that in some MDs is larger.
                            Tesoro defines various disc circuits as D90, ED120, ED180 where number indicates degrees interval of disc employed: for example , if I remember well, the compadre uses ED120 so 120° of disc interval.
                            The tuning for geb is made in a way you sample RX signal at around zero crossing; disc instead has a starting point of sample depending of the disc circuit employed in the particular MD... then you can "slide" the sample in a way you cover a sector near the peak of RX signal. The geb/disc sampling strategy is made in a way you have always around 90° phase-out between the two... so that's why you sample one about at zero crossing and other channel at about peak of sinus.
                            When you build a clone of e.g. bandidoII or TGS you end-up (if do all right) with already "partially" tuned device: you have to set then e.g. geb according to soil (there's a knob for manual setting on bandidoII) manual for each soil or (like in TGS) using a preset trimpot: when you use a preset trimpot, sure you tune for a medium worse soil, but sure this way you actually cannot use MD in other very bad mineralized soil... unless you unsolder the trimpot and add a manual control on front panel, like a multiturn pot (similar to bandidoII situation).
                            The fact you have many trimpots say just this: you have many factory presets.... and solution for to make your MD more easy on worse soil is e.g. translating geb into manual mode using a real pot instead.
                            Usually the machines with many presets are for easy soil and ease of use.... like compadre is but do not give warranty on worse soil conditions like others can give (e.g. toltec or also bandidoII): original tgs is also this way about geb (tesoro made it with fixed geb preset... so an internal trimpot), but has other controls accessible to the user.
                            Kind regards,
                            • #44
                              Compadre Pots
                              Thanks Max. It will take some time learning how these circuits work so I appreciate your patience with my beginning questions.
                              If anyone is familiar with the new Compadre, I'd like to confirm the meaning of the three trim pots on the circuit board. I have been moving them, but not really understanding what I'm doing, so it is time to better understand before I make a mess.
                              The attached picture shows approximately where the pots are if you hold the metal detector in front of you as if you are using it.
                              Steve in MS identified the top pot (#1) as the gain pot. I think it was factory preset almost full counterclockwise except for a 1/4 turn. By turning it full counterclockwise, the gain increases slightly and I increased my depth in air from about 5 inches to 6 inches and maybe more.
                              But when I put it on the dirt, it beeped intermittently, any movement made a beep.
                              I tried turning the other pots to see the effect. I found that if I turn pot #2 fully clockwise, the ground does not make a beep. I think this configuration may be a little better than the factory setting, but I didn't record the exact factory setting (stupid me). If I turn pot #2 counterclockwise more than a tiny bit, the ground starts beeping.
                              Pot #3 I cannot determine what the effect is. It may shift the discrimination settings on the DISC knob control on the front of the unit. But I'm not sure. I have set it sort of in the middle range where I think it was from the factory.
                              Using air tests and my new settings, the Compadre discriminator part is still working quite well. A setting to Iron cuts out a paperclip but allows a nickel and a 14K gold ring. Setting to Foil allows a nickel but cuts out the gold ring. Setting to nickel cuts out a nickel but allows a dime, penny etc.
                              Although increasing sensitivity (pot 1) does increase air depth a little, I don't know if it really increases it in the ground. I would need to test that, but it is difficult to open the machine outdoors and work the trim pots and get reliable measurements with buried targets.
                              As Max says, it would be nice to have these pots on the outside. Because they are tiny surface mount parts it would be tricky to do that surgery, and I would think the long leads might cause circuit problems. One could perhaps drill tiny holes in the case to access the trim pots from the outside (letting in dirt also). But trim pots probably might wear out, not designed for much turning.
                              So if anyone knows for sure what all these pots do and how they interact, I'd like to hear. In time I hope to trace the circuit so we can analyze it and compare it to existing circuits.
                              Cheers,
                              Kind regards,
                              • #45
                                Cheers,
                                Have you considered that the Compadre is perhaps just not as sensitive as some of the other Tesoro detectors?
                                Have a look at the attached chart:
