Was curiuous what was available on this machine
Tesoro Toltec 100 schematic and adjustment?
Toltec 80 schematic
I drew this some time ago and don't remember if it is complete or not. But maybe it's useful to someone.
I've just found out that the schematic I have is a Tesoro original one from a service manual and so I can post it for copyright reasons.
If you want to know what the pots do I can tell you that and what the signal paths are. Sorry, I'm really disappointed I cant help, but the guy I got it off has told me not to post it as he thinks that Tesoro put DIFFERENT errors in each copy they let out to authorised service centres and so this would point straight back to him and cost him his livelihood, and I can't be the cause of that in fairness can I? Also I don't want to cause any problems for the forum.
Merc, fine. but a best way is to share up the scanned PCB's sides. much people do speedy the trasing copy using Sprint Layout-5. it has possibility to put an image as some mask. then you not need in the schematic because you get the all PCB image not waste the time. in SL-5 you can also save the result in Gerber file.
