PCB CAD/CAM Software
  • PCB CAD/CAM Software
    Carl, what software are you using for PCB design, i tried some free demos like Eagle from cadsoft but can´t generate the Gerber files, am i missing something ? thanks
    I use "Easy-PC" from the UK, http://www.numberone.com. It's pretty cheap, and has good features. I suspect the free version of Eagle does not generate Gerber.
    - Carl
      Eagle PCB Gerber-out
      The freeware version does appear to have the capability to output gerber. You need to use the CAM Processor. See instructions below:
      Generating Gerber Data with the CAM Processor
      The same steps are usually required for each board whenever films and
      manufacturing data are generated. This process can be defined as a CAM
      Processor job.
      The file
      gerber.cam, which can be found in the default subdirectory for
      CAM jobs, automates the output of Gerber data for double sided boards.
      Attention:
      The process described can only be used for Gerber photoplotters
      with flexible aperture wheels, not for photoplotters with fixed aperture wheels.
      Please contact your board house to confirm which data are needed.
      Load the job into the CAM Processor, either by double-clicking the entry
      with the name
      gerber.cam in the Control Panel's tree view (CAM Jobs), or
      by clicking the CAM Processor icon in the Layout Editor window and selecting
      gerber.cam
      in the file dialog (Þ File/Open/Job).
      In case you have started the CAM processor from the Control Panel, load
      the board file
      demo3.brd:
      Þ
      File/Open/Board and · · demo3.brd
      Click the button
      Process Job and confirm both prompts Delete name.$$$...
      and
      More than ... with · OK.
      Now all of the necessary files will be written into the
      Project directory
      (where the drawing and board files for this project are located).
      The files have the following meanings:
      demo3.cmp
      Component side
      demo3.sol
      Solder side
      demo3.plc
      Silkscreen for component side
      demo3.stc
      Soldering mask for the component side
      demo3.sts
      Soldering mask for the solder side
      demo3.whl
      Aperture wheel file
      demo3.gpi
      Information file, not relevant
      demo3.$$$
      Temporary file, to be deleted
      The first six files need to be sent to your board manufacturer.
        Qiaozhi, thanks for your help !
        Carl, the software seems to be very good,...did you buy it on-line ?
          Yup.
            diptrace
            You might take a look at this package:
            www.diptrace.com
            Pretty good with a simple to use autoroute PCB package and the price is right for hobby use.
              free pcb software
              Kicad is an open source (GPL) software for the creation of electronic schematic diagrams and printed circuit board artwork.
              http://www.lis.inpg.fr/realise_au_lis/kicad/index.html
