Golden adjustments
  • Golden adjustments
    Looking inside I see 2 square blocks that look to be adjustable. DOes anybody know if one will adjust the ground balance ? I am looking to just make it a slight bit less positive.
    bandido ii umax coils . tx & rx
    hi
    i build a bandido ii umax .but i have a problem about coils this circuit . i know not that plan coils . i need hard to coils this circuit .( tx & rx). i want turn & value & number wire.any one can please help to me .please . tank you
      R43 is the GB pot.
        Ground adjust Golden
        When you do ground adjust for (golden) tesoro, check that you still can find large silver coins ! ( I know ...... )
        The other adjustment in the golden is for notch band-wide.
