Garrett , Sea Hunter xl 500
    They are shown on the board, but are really on the control PCB. The power switch, Audio is the threshold level and the eliminator adjustment.
    All of these are adjusted during the search. No calibration adjustment are on the PCB.
    Tim
      For Tim
      Excuse Tim, but the trimmer from 25Kohm that it regulated the offset one of first the operational one on the PCB, that one it goes regulated or not? And how many coils I must wrap oer the coil? Thanks
      PaoloItaly
        I will check that 25kpot. I will make sure it is as shown on the schematic. What size coil do you want to make?
        Tim
          For Tim
          I would want to wrap a coil from 8,5 inches for the Sea Hunter, that thread I must use? Thanks still.
          PaoloItaly
            XL500
            Do you have the XL500 pcb file?Please send the froum ,if ok.Thank in advance
              Hi, I just posted a small report on the Xl500 here used with the logger.
              http://lrlman.com/Pages/Reports/XL500.pdf
              I have information on a 14"x18" coil and a 3'x3' coil. The XL500 surprized me as far as depth. But you do have to watch the threshold. Overall if you want a deep machine and can make a coil the XL500 will do fine. You can pick one up on ebay for around 200.00.
              Tim
                PaoloItaly, I do not have the PCB for the XL500. Maybe the person that posted the schematic may have the board also.
                Tim
                  XL500
                  Thanks for the reply.Please send me the 14x18 coil details.
                  Thanks in advance
                    this test results really good for PI
                    THis looks better than delta pulse
                    does anybody has pcb layout and component list
                    does pcb one sided or two sided like delta pulse?
                      Hi. I enclose the design of the PCB and that relative to the assemblage for the costruction of the XL-500 Sea Hunter. I hope you can be useful.
                      Soon.
                      PaoloItaly
                      XL-500 Sea Hunter - PCB.zip
                      XL-500 Sea Hunter - Assembly Plans.zip
                        XL500
                        Hi paoloitaly,
                        Thanks for your files.Do you know about the xl500 coil details?
                        Have you built this detector?
                        Thanks for your help.
                          PaoloItaly
                          Hi. I already possess the mounted circuit of an old XL 500. And thanks to the outline of Diminute are successful to repair it and to make it to work, and from that circuit I have gained the plans that then I have sent to you.
                          Salute.
                          PaoloItaly
                            In the top form ???
                            In the XL500.PDF, 14X18 coil there is a part that say "that fits in the top form" ? What's the meaning of that ?? or What does mean ???
                            Sorry for my bad English... & thank
                            diminute
                              Xl500
                              Thanks for all information that sent in the froum.
                              I want to know the 1mx1m coil detail of xl500.
                              Do you have schematic or files about SX500?Please send me if ok.
                                I am working on another XL500 for a friend. I am making the larger coil for him also. I will post a PDF on the coil soon. It may be a week or so before I do. It will have picture and ideas.
                                Take care,
                                Tim
