Garrett , Sea Hunter xl 500
  • Garrett , Sea Hunter xl 500
    I just purchased one off ebay. What are the odds of getting a schematic on this puppy?
    Thanks,
    Tim
    I have one, but no time to draw out the circuit. Haven't seen a schematic for this, either. Sounds like it's up to you!
      ok
      Çreo que es este... I believe that It's
      Thank
        Thanks diminute, I will check it today against the board. The chip numbers look the same at a glance. The detectors at the shop. I will let eh forum know.
        Thanks again,
        Tim
          So far so good! I checked points along the signal path and saw what should be there and all main parts are the same. I tried to buy extra connections from garrett for coils I am making and a connection to my logger. The prices about knocked me down! 30.00 for the headphone and 20 for the coil connection.
          If anyone knows a suppler that has these let me know.
          Thanks again,
          Tim
            Is there a diode drawn backwards?
            I don't see hoe the phones get voltage.
              Goodrat see the schematic for the charge circuit through the phone jack.
              Boo
                J1
                This design use the same input for charger and for headphone.
                Is a pretty solution to use only one jack.
                Thank
                diminute
                  Neat but..
                  The diode blocks the battery voltage from driving the phones. I don't see where the power comes from.
                    Look at the connection J1. Thats where the phones and charger connect.
                    Tim
                      Not at the same time...
                      ...I assume. So when the phones are just connected, where does it get voltage?
                        This is like Hammerhead... the (+) side of the battery is ground, and the (-) side is -12V. So the JFET drain is at "0V" and the low side of the phones is at "-12V".
                          Oh, I see...
                          I see that connection at the switch that goes to ground now.
                          Is this an old model?
                            Carl do you know the year they last made these?
                            Tim
                              For Diminute
                              Hi. Regard to scheme of Garrett XL 500, i wanto to know the data for the costruction of the coil and that relative you to the calibration of the trimmer on the circuit board.
                              Tanks.
                              PaoloItaly
