That detecting of metals to build?
  • That detecting of metals to build?
    I would like to build me a detector of metals with some benefits that are but or less good to see if alquien can seek advice something on the topic and the best option for it.
    I am technical in electronic industrial and I believe that I have the necessary means for it would like me to it to mount me a detector with some good characteristics but not you which it is since the best option is different types of detection of metals, I have already used some
    I have seen many outlines and assemblies of the same ones in this forum but I don't finish telling me since not for one you many things on these assemblies and if they work or I would not like that has
    - adjustment of earth manual or automatic air
    - adjustment of sensibility and good depth
    - discrimination of strong metals
    I don't care him to have screen of liguido glass or anologico and that it is of two different tones. They could program me a microcontrolador I find that it is a very good forum of the best thing that I have seen, without but a coordial greeting to all those of the forum and to have if I can build myself one to enjoy the nature and of good hayazgos thank you
    A couple of good circuits that meets your requirement is the Tesoro Silver Sabre, and the Bandido II. They are discussed in the Projects forum.
      That detector to mount of both for characteristics has information?
      Which would mount your for characteristic of the two detectors that you have told me and for information to complete with success; Not you if the data that you/they come are up-to-date, to have if you can spend the up-to-date data of the detecting outline and pcb that your you believe but convenient and anything to begin to mount it and I will already count you like this goes thank you carl without but a coordial greeting.
      I have seen little information on the search reel and as mounting it to have that you can make in this respect
        You lost me in the translation . If I were to build a Tesoro circuit, I would probably make a Bandido PCB and start out building a reduced version (similar to the Silver Sabre circuit) on it. The SS is just a 2-channel version of the Bandido. I would start out with a Tesoro coil to get it working, then perhaps build a custom coil later. Older Tesoro coils are fairly cheap.
