Originally posted by Carl-NC
Really sensitive pinpointer for grain size objects
I have done a similar setup with the Fisher F-Pulse. Here are some suggestions:- Increase the coil to a higher inductance. I use 1.3mH. This will decrease the TX per-pulse power consumption.
- The pulse width is fine, but increase the pulse rate as high as you can. This will increase sensitivity and increase the TX per-pulse power consumption. I use 2500-5000 pps.
- Increase the clamp resistance (R23+R27+R31) to several kΩ. I use 10k. This will significantly speed up the diode recovery time. It also increases thermal noise but you won't notice it.
- Likes 1
Hi Carl,
First, thank you for suggestions.
My experience in metal detecting is very modest but I have some question to you:
Increasing of the value of the safety resistor in the input of scheme (50 times to 10K) will increase seriously the current noise. I think this create problem. To fight with this problem, you need to increase the repetition rate to 2500pps.
What is the summary profit?
Also the peek current via input resistor with 200 oHm is 50 times bigger , but discharge of current carriers in diode via 200 oHm is also 50 times faster, or not?
What is "direct sampling" - this is new idea for me.
In this document you see second, more complex variant of the coil. This variant uses wire with teflon isolation. Reducing of the capacitance of the coil allow to reduce the receiving delay to 3us instead of 4us.
This add sensitivity to sub grain targets. This is the best cable for the coil, but relatively hard to find and more expensive than magnet wire with 0.4mm external diameter.
Attached is datasheet for this teflon cable.
It is interesting that cable with 0.4mm diameter is optimal for pulse detectors. Thinner cable have more resistance by meter and not allow big currents. Wider cable is sensed as target and not allow short delays.
Litz wire maybe is the solution, but on price of hard finding and more more expensive price.
Originally posted by Carl-NC View PostI have done a similar setup with the Fisher F-Pulse. Here are some suggestions:[LIST][*]Increase the coil to a higher inductance. I use 1.3mH. This will decrease the TX per-pulse power consumption.
- Likes 1
That is a 4mm steel ball, jus testing mentioned LVDT principle, marks are at 1" and 1 1/2", Rx coil is connected directly to oscilloscope without any processing.
https://www.youtube.com/shorts/aVN0CnoN8BE
adding simple electronics will increase the sensitivity, by 2 times - expected
