Walk Through Metal detector Circuit digaram
    Yes In my circuit both coil winding with same. in lower sensivity the circuit is ok, but if I increse sensivty a little circuit is unstable. What the good other relacement for FET transistor BFW11 ?
    Is there any way I use Oscilascope here for fine tune the circuit ?
    Regarding Gold PIC microconterller PI there is no Code for microcontroller. I already start making grys PI PCB , hpefully very soon i will make it. But I need Idea about its coil , how can I use it as walk through.
    What do you think about T/R Locator Metal detector ( http://sevzirfo.narod.ru/trlocatorver1.gif ) , and which two box circuit is best for me in your own experiance.
    Could I use T/R Locator metal detector as following form, both coil will be paralal or perpandiculer ?
      This is how most walk-throughs are designed... multiple TX coils on one side, and multiple RX coils on the other. They create detection zones.
      I own a Garrett walk-through, always intended to take it apart and show how the coils are set up, but never have. It's that round tuit thingy...
      - Carl
        Walkthrough metal detector is very interesting. I am very much interested about this. But I never found any link in internet and no other forum ever discuss it before as much here i found . Carl we want more .
          This is a picture of a multi zone coil inside walk through. It is may be TX RX system. But its circuit is too complex That I cannot understand. I need help plz.
            my messanger and email address
            Hi
            My email and messanger address is : jamil_tech@yahoo.com , goodboyhk@yahoo.com
              According to the Gold PIC website: The semi-kit contains a bare, fibre-glass, tinned, single-sided printed circuit board, the pre-programmed microcontroller integrated circuit containing the embedded software, printed assembly instructions and the circuit schematic. The microcontroller is 'code-locked' to prevent duplication of the firmware.
              In other words you need to purchase the pre-programmed microcontroller. Once you have the working microcontroller (and you can see how it works) it should be possible to create your own source code to do the same thing.
              See last reply in this post.
              I don't think a 2-box would be good for this application. These detectors are designed to detect large cache sized targets.
              According to Carl, this is the usual coil configuration, and in the images you posted it looks like they are parallel, so I suspect this would only work well for a P.I. circuit.
                Here's a neat explanation of how a walk-through detector works (with animation) -> http://travel.howstuffworks.com/airport-security3.htm
                Depending on the complexity you require for your project, multi-zone coils may not be required. Just have a big loop on one side of the arch connected to your P.I. circuit.
                  HI Qiaozhi
                  Thanks for your lots help. Please tell me finally which PI other then gold scan ( coz it will complex my project for searching coding ) you personally tested and found best performance, if possible please send me revised schematic ( coz my previous experience most of schematic have some problem only expert people can solve this) with PCB layout and parts list. I like to test one, which you tested already.
                  I am sorry for troubling you so much. You may thing me a lazy student, but believe me I already made half dozens circuits and no one is satisfactory label.
                  vbmenu_register("postmenu_48248", true);
                    Originally posted by jamil_tech View Post
                    HI Qiaozhi
                    Hi Jamil,
                    Many people here have successfully built the Hammerhead. It was designed by Carl as a project to learn how P.I. detectors work, and to allow you to experiment. I have not built this myself yet (maybe one day) but this is a known good design. Also, if you get stuck, there's a special Forum under Projects for the Hammerhead where you can get advice.
                    Another one that might be worth looking at is the Sandbanks P.I. -> http://geotech.thunting.com/cgi-bin/...anks/index.dat
                    Personally I would go with the Hammerhead.
                      What do you think about Delta Pulse and SNIFFER XR-71 ?
                        I need a information, I found most of the big coil metal detector use PPPEAR or MPEAR capacitor, which is rare in electronic shop. Can I use myler or ordinaray capacitor instead of this capacitor.
                        What is the good replacement of transistor BFW11 ?
                        Jamil
                          Jamil
                          Is this capacitor for an I.B. or P.I. design?
                          I checked in a transistor guide and there are two possible substitutes for the BFW11 -> BFW16A or 2N4416.
                            what kind of metal detector of my design
                            First i need to know what kind of metal detector of my design ( Schematic I post already ) . Is it IB or frequency shift type?
                            and is there any same kind of circuit you see before? if yes plz give me link.
                            thanks
                              thanks
                              Do you have a better schematic than this one?
                              There are several component values missing and no pin numbers on the ICs.
                              At first sight it looks like an I.B., especially since there is a tuning capacitor across the TX coil, but this is an unusual design and really needs to be redrawn in order to get a better understanding of its operation.
                                this walk-through metal detector is a very interesting topic in this forum. But unfortunately very little information in web . If anybody have more information regarding walk-through please share it here in this forum. I am a new learner but i am very much interested about walk-through circuits. I am sure there is a big difference between walk-through and coin hunter metal detector. So it is not a very good idea just make a walk-through metal detector from a coin detector.
