TIGER SHARK WIRING PROBLEM
  • TIGER SHARK WIRING PROBLEM
    Greetings.
    I have a Tiger Shark metal detector belonging to a friend with a problem connecting the main PCB to the control PCB. The connecting wires between the two PCBs—16 multicolored wires—were ripped apart during a battery change due to an unfortunate accident. Is there anyone who can provide me with guidance, including a photo, on how to connect these wires correctly? If possible, I would also appreciate a schematic to check that everything works.
    Thank you in advance for your cooperation.​
    Click image for larger version  Name:	image.png Views:	0 Size:	274.1 KB ID:	429361
    Copper braid for cleaning tin and remove the extra tin.
    Looks like somebody tried to reverese ee on this?
    Is that Microchip PIC or what?
    Maybe "burned" ?
      thinking the micro had been died. catastrophic case.
        It looks like some water mist or a wet finger touched that area. Now the tin and copper are reacting causing the corrosion. Soak the pcb in alcohol and scub gently with a soft toothbrush. Repeat until clean. This is common problem with water detectors.
        Hopefully the pic chip will still function, otherwise as kit315 said "catastrophic "
