I urgently need help from someone who is willing to help.
  • I urgently need help from someone who is willing to help.
    Good morning friends, I want to fix my device but I need the diagram, would anyone here be willing to share the diagram of the nexus mp please ? thank you.
    Your image did not upload properly, please try again.
      Thanks Carl, I'll try again and explain better what happened. "I urgently need help from someone who is willing to help, I bought a Nexus mp from someone and apparently the electronics had already been touched, I used it a few times normally, and the last time after walking for 5 minutes in a field, I found a large target that made a big explosion in my ears, making a deafening sound and then just silence, my coil only responds to large ferrous targets at 5 centimeters, I opened my detector to see if there was anything apparent, but I only found one thing missing (marked with a circle in the photo), and I don't think it has anything to do with the problem, I need Click image for larger version
      the schematic to track if there is something with the circuit (normal sound response with the detector connected without a coil, but once connected, no response), I need the circuit schematic to look for the problem with the circuit or the coil (10 bits 7khz), I attached a photo of the circuit but it was not uploaded (thanks Carl for letting me know, I hope this time it will be possible).
        In the photo there is a potentiometer missing but it was because I removed it to remove suspect components to be able to test it outside the circuit and I still haven't replaced it, thank you for understanding.
