mixed schematic Tesoro golden, bandido
  • mixed schematic Tesoro golden, bandido
    Before the realization I would want to subject this schematic obtained from several schematics Tesoro. thank you for comments and/or improvements.
    the circuit seems really like bandido II (not golden)...some differences are in disc and geb parts. Also components are really close to bandido. Voltage converter is for sure better than in bandido II umax.
    Can't say about performance but I guess is the same of bandido or really close to. I think you need a good coil to get it work...expecially for disc mode that is the most difficault section to tune in this kind of circuits.
    Best regards,
    Max
      The pin numbers on the voltage regulators appear to be incorrect.
      They should be:
      7805 -> 1=vin, 2=gnd, 3=vout
      7905 -> 1=gnd, 2=vin, 3=vout
        ok
          Hi Marcello and all,
          I've noticed that caps in disc/geb are equals to Carl's bandido II umax schematic...
          That is interesting...to know that seems these are correct values also for bandido II uMax too, can't be a coincidence !? Or what ???
          Where did you find this schematic of golden ???
          Have you reversed it from pcb or something ???
          Have you measured values in circuit or out-of-the-circuit ???
          Best regards,
          Max
            for this circuit I will use the head original of tesoro umax. The Golden I have taken it from a post of Carl. For the CAP they are from trying under final testing. I have already realized bandido II eliminating nearly completely the CAP. thanks to all for the aid
