Pulse IB discriminator (by Sasho - Varna)
  • How to check up on working capacity the block without the spool? For English excuse, it not I, it "Promt translate". All I thank.
    • HI THIR IS THIS PULSE INDUCTION DETECTOR AND CAN I USE TL072 INSTEAD NE5534 AND CA3140 PLESE TELL ME
      • IS THIS PULSE INDUCTION AND CAN I USE TL072 INSTEAD NE5534 AND CA3140
        • HI SASHO PLESE TELL ME WHAT KIND OF THIS DETECTOR AND CAN I USE TL072 INSTEAD NE5534 AND CA3140
          • It is possible to see the working instrument (give a photo of the ready card)? On printed circuit cards that tip122 turned bc517 not correctly costs, c7 it is overwound. Who can нибудь give the normal instruction on assemblage of this instrument? And that was laid out by the subquality work rejected and be silent!!! This big disrespect for all present at a forum!!! I have gathered it (but did not connect the coil), and he is silent. Give a complete manual...
            • Comment
              • CAN I USE TL072 INSTEAD CA3140 AND NE5534
                TL072 yes,
                they are not pin compatible but should work electrically ok , performance may not be the same, but should work.
                • SMITY ask leto he built this detector from his own PCB
                  • 6666, zum, ODM
                    You have started to gather the instrument? What turns out? I have gathered, but it does not publish any sounds. While the spool did not do, wished to check up working capacity of the electronic block in the beginning. And respected Leto, Ivconic, Geto has made this instrument for a long time already and it is uninteresting to answer our questions.
                    • pulse ib
                      any one help me , is this circuit pulse induction detector and what about the coil what 30w mean
                      • yes ,this is pulse -induction balance.It detects only non ferous.30w means 30 turns of copper wire.It can work with CC coil,or DD coil.
                        • PULSE IB DICR
                          HI EVERY THERE CAN ANY ONE GIVE ME INF- ABOUT COIL ,HOW CAN WOUND THTIS COIL AND WHAT LINE NEAR THE COIL IN DESIGN MEAN
                          • Respected ZUM. You included the instrument without the spool? For me completely is silent. How the circuit works for you after inclusion (the sound is present at dynamics?)?
                            Make please a photo of the device (from above and from below) in high quality and send to me [email protected], or place in this section. In advance I thank.
                            • Please upload PCB
                              • Originally posted by emoxristov View Post
                                Please upload PCB
                                Look at page 7, post 151
