Hi Ivconic
I never put the pcb of Anker inside box (i made it with 2 general purpose pcb's 10x16 cm) so it is not easy to make a field test.I made only air test and compared it with CL3, XLT and GTI2500. At the air the SS60 is better.... best sensitivity good audio and good disk (two tone). On winter i will make a pcb for it so i will finish the project and it will be ready for work and for tests. One time i tried the Bandido (not with original IC's) but the results was not good (Bad). Maybe on Oktober i will try the TGS and i will tell you the results and the comparison with SS60. For me it is better to be better than SS60 because so i will have a fine detector. Anyway i will read all your posts here when i decide to construct it.
