Metal detector with meter discriminating
  • #46
    When I search for capacitators in shops and they ask me "in which voltage range???"what shell I answer???
    please help me I am realy a noob!!!
    • #47
      Hi
      Hi,have anyone finish this PCB?
      • #48
        Any voltage rating that is Greater than the Battery Voltage shoud be OK.
        • #49
          Polarized capacitators-16-25 volts.
          No polarized capacitors-63-100volts.
          • #50
            to SASHO-bg
            Hello,
            Thanks for fast replys!
            Sasho can you tell me R42 is?k,m or?????
            • #51
              to SASHO-bg
              And the potentiomters are?Lin. or Log.?
              • #52
                to SASHO
                Hello,
                Can I use LM358D insted of Im358?
                Sorry for the stupid question,but you will HElp me this way!
                • #53
                  The potentiomters are Lin.
                  LM358D-no problem.
                  • #54
                    to SASHO
                    Thanks!
                    And what about R42?I should chouse right range to achive 9V according to what have I put together or what?
                    I have trying to make PCB for this circuit whit sprint layout 4 ,because I cant find to download sprint layout 5!!!
                    And almost finish,but still a lot of work on this!!
                    I cant wait to test the finished machine!!!
                    Can you tell me about the coil:
                    This is OO coil?
                    And as far I can see there is no switches ot this circuit,except S1 on/off??
                    Thats good I hate switches.
                    • #55
                      Yes,
                      Sasho please explain R42?
                      • #56
                        R42-adj.+9v with trimmer 22k.
                        • #57
                          to SASHO
                          Hello,
                          I mean isnt R42 resistor?What is it's value,because its not marked on the schematic!
                          Tks!
                          • #58
                            Select the value of the resistense of R42 bey trimmer so,that yon can have +9V on the exit on the stabilizer.Set the neherest pesistor nominal.
                            • #59
                              to SASHO
                              SASHO!
                              Thanks.Now you make it clear!
                              • #60
                                Hello,
                                Can you please tell a little bit more about this coil?How should I conect it with the detector?
                                How you make TX coil with 3 outputs?
