P.I. Long range Detector
  • #61
    Sasho kakvo da navia na zagotovka 38 cm za tazi ma6ina?Blagodaria.
    • #62
      hi sascho! How many turns for a 0.5m x 0.5m loop? 24? or...?
      Regards...Kawly
      • #63
        Sasho.
        This looks like very interesting schematic indeed.
        Can you give some details.
        Like what value we shell use for DR1?
        Also is 74HC4538 OK for this design?
        What wire do you use for the coil.Normal copper wire like in VLF?
        • #64
          D=38 sm-21turn
          0.5m x 0.5m loop-19 turn
          • #65
            Hello
            PCB drawn by Asenkron at Turkish dedektör site.
            http://www.detector-planet.com/dpfor...opic,32.0.html
            Please check it,nobody built it yet.
            Best Wishes
            Erol
            • #66
              Не употребявайте PI детектори. Те създават много силно електромагнитно поле.То е опасно за здравето.Може да създаде сериозни проблеми за хора с песмейкъри.
              Do not use the PI detectors. They create strong electromagnetic field.To dangerous for
              health.Possibly to create serious problems for people with pacemaker.
              • #67
                Sasho,
                Please give little help here.
                Now the only thing that left is the value of drossel1?
                What we should use? 1mH?
                Is resistor like ok there.
                PCB looks rely good.Can't see mistakes.
                So I will begin making this unit.Looks like good first PI to me.
                • #68
                  20-100mh or resistor 36 om/0.5w
                  • #69
                    Thank you very much!
                    • #70
                      Originally posted by 1843 View Post
                      Hi all,
                      I made this PI. It works excellent and can beat my Deltapulse.
                      I suggest all to make it.
                      Many thanks to Sascho for this design,
                      1843
                      if so... someone will made a pcb sooner or later. I didn't made it cause have already too many PIs for my taste!
                      Now that I'm looking for new stuff I see that some Sasho's designs are really what I need!
                      So really thanks to him!
                      Kind regards,
                      Max
                      • #71
                        Hello
                        Part placement diagram attached for pcb.
                        Please be cerafull blue line connections on this Pdf
                        which Not shown before.
                        Thanks to Asenkron for good Pcb.
                        Erol
                        you have to be register to see page contents.
                        • #72
                          erolunal.
                          Can you please post the other views too for this PI.Like in Tesoro mod R theread?
                          • #73
                            Zdr. Sasho!
                            1. Na kolko to4no balansirash izhoda na 5534 ?
                            2. Kakva e konsumaciata i dostata4na li e Batt 12v/1.3Ah
                            3. Kakvi sa vremeintervalite za diskriminacia i otkade se vzema strob
                            Predvaritelno blagodaria!
                            • #74
                              Hello
                              I attached all files to zip.
                              Best Regards
                              Erol
                              • #75
                                Except few unknown capacitators and the upper conection around NE5534/where is conected this resistor to pin 7 and 8 or just to 7?
                                Every thing else looks cool.
                                Very elegant PCB.
                                If anyone spot mistake please alert.
                                I am in the middle of collecting parts.
                                Found those damn 4393
