Neki bi da stalno provociraju druge , ne shvatam to u ljudima mislim na Ponpeja , dajte molim vas koristite jedno ime jedan logo kao ja a ne sakrivajte se i koristite po deset imena i i imate za sve sto vam ne odgovara drugo ime
Serbian "Most Wanted"
Originally posted by Geo View PostYesterday i made a real test at a farm with the Cesar and the Sovereign.
I found a very thin copper coin at about 25cm in heavy terrain. Sovereign located it very strong, and cesar not so good (it wanted the coil to be very close to earth so to locate it). On air test cesar is better but at ground Minelab is better. But it is fantastic for his money.
I tried both with 15" coil. Maybe another time to test both with smaller coils, for the time i have not yet smaller coil for the Sovereign.
Hello, GEO! Very good result likes me the same coin of how many centimeters it will register in the air at the same position on the GEB and TUNE, the coin is what size? GEB of severe soil how it works? How is discrimination?
Предложете по-добър превод
Originally posted by georgi.g.zhelev View PostHello, GEO! Very good result likes me the same coin of how many centimeters it will register in the air at the same position on the GEB and TUNE, the coin is what size? GEB of severe soil how it works? How is discrimination?
I can't tell you exactly because i let the coin to the car of my Friend (very thin.... no good). I can say that the coin was something between 18...20mm and 1mm or less thin.Sovereign has a handmade 15" DD coil and the Cesar a BlueMax 1500 (15"). As i saw Cesar located it at 35cm on air (about... not meter) and the sovereign at 30...33cm. With both detectors i had not problem with disc and Geb. The Disc of Cesar was at the point 6..7(about 1 o'clock). Disc and notch of the Sovereign was to 5 position (11 o'clock).
Pozdrav svima napravite jedan jednostavan test . Postavite ispod jedne pune cigle debljine 6cm novcic 18mm a pre toga nastelujte detektor da ne svira na samu ciglu sa potenciometra za graund balans a diskriminator podesite tako da ne vidi gvozdene predmete . Videcete sledece skoro svaki detektor koji ima dd sondu probija ciglu i vidi taj novcic , a svi detektori koji imaju koncentricni ili koplanar sondu taj isti novcic nece videti e toje objasnjenje za to sto je nas prijatelj probao cesara i soveringena pa je soveringen bio bolji kod cesara stavite iskljucivo dd sondu koju je ivonik opisao i videcete da je to prava stvar i manite se blue maks itd mislim na koncentricne sonde . Molio bih prijatelje koji znaju engleski da ovo prevedu realno.
Originally posted by Geo View PostHi Lari.
If we see it better it is a cheap Fisher model with very good depth. It is not better than the Top models. Simple, it is very very good for its money!!!
It is best to do DD probe of normal size with good adjustment and probes the data presented here
results are the best. The coins is the best probe of 22cm to 27cm
All the best
Originally posted by lari View PostGeo coil that uses a very large and not good for this type of detector.
All the best
I know it but i wanted to compare the two detectors with similar coils. I also have a BM950 (9.5") for the cesar. For bigger coins (>22mm) the 15" gives better results on the air.
Now i am looking for a 12" coil for my Sovereign. If i will buy it then i will let at the side the Cesar.
