Serbian "Most Wanted"
  • Thank you my friend
    but
    Picture is not clear
    • Originally posted by moltazim View Post
      Thank you my friend
      but
      veri good bitmap draw path in sprint. zum see beter.
      https://www.dodaj.rs/images/n0JZ2.png
      sprint path wark
      https://www.dodaj.rs/images/n0MDJ.jpg
      • Comment
        • Can electronic components be displayed on the image?
          • Comment
            • Originally posted by pustareka View Post
              SMW PCB
              Just tried to view lay file again-msg- contains no bmp img. Displays only IC's and 1 (bottom layer?)trace.
              Pustareka if possible please check this file.
              • again and again, why you dont ask user Walkman for sprint layout files?
                he is member of this forum
                • Steady up Bernte. Don't bite my head off. I am merely trying to make Pustareka aware that he has posted a bogus link....but if walkman is still present, he may read this and post correct lay. Sheesh. I did ask politely.
                  • If this can help.
                    SMW_v3.zip
                    • Hi Tim, this didn't aim on you. Pustarekas postings are strange
                        I asked him but he does not have the pcb layout
                          Hi friends,
                          I did draw SMW3 but not test it. So I do not want to add
                          if you want to test if you can add.
                          • Originally posted by walkman View Post
                            Hi friends,
                            I am doing it
                            I will inform you of the result
                            • Thanks chevesne. All good Bernte. Moltazim that is very good. I will be soon updating to paid Sprint to also scratch out some pcb's for some designs here.
                              • you can find sprint layout in the net with a crack
                                i bought sl6 because i want to Support the Inventors from Germany
                                also possilbe to use sprint layout Viewer, the print function ist blocked as i remind but is is possible to take a screenshot
                                you can print the pcb tracks easily with paint or what else it is only necessary to print the right Ratio of the Picture file
