Serbian "Most Wanted"
  • Maybe voltages V+ and V- get affected?
    • Originally posted by salih View Post
      in my SMW I have problem There is an inverse relationship between sensitivity and volume key . When the sound is low Detecting coin in the air 40cm . When the sound is high Detecting coin in the air 29cm. I use BC517 Instead of MPSA13. help.
      You need to post good pictures of the front and back of your printed circuit board that you built.
      • fine tuning the capacitor determines the distance and successes+coil...
        • new sound
          cezar sound new
            You must connect the negative speaker wire just where is connected the negative cable from the battery. The negative rail of the PCB, it is no able to supply the necessary energy. In the past I have had the same problem. Hope you helps.
            • you r really helped me
              you really helped me I was wrong to connect ( + ) and ( - ) in the speaker. Thank you for any one contributed in helping me
              • Advice
                Advice 4 all Test smw at home or at the Workshop not real results. I test smw in my home results Detecting coin in the air 40cm When the power goes out of the neighborhood Becomes smw More stable and Detecting coin in the air 45cm. Regards
                • Very true. It is also true for all other detectors. It also means that your detector is optimally set with gains and all. What you experienced is noise reduction of some 6-10 dB.
                  Now imagine using LF frequencies instead, where background noise is even less.
                  • deep stable and interference detector is very good and not based SMW
                    • View the condenser coil current I (docx) will not load here can I help
                      • Why not?! There are many ways to "skin a cat", and some are only more elegant than the others. The end result is more or less the same: treasure in your pocket.
                        • solid phase solid sound at full volume refuses'm building a new sound
                          • bc 160 transıstor -2v7 delete ....led dıode fine ....ferros nonferros led diode
                            • my video
                              http://www.dailymotion.com/video/x10...-144920-1_tech
                              • What coil did you use? Did you build it? I would prefer if the coin was glued to boards/sticks for the tests. Nice looking hands BTW, it looks like they haven't dug a thing out of the ground! Do you wash dishes a lot?
