Yes I will buy too. I have used demo version to print for etching, but I would rather professionally made boards (from ALLPCB) at AU$4-6 each, who require Gerber files, so Gerber to Sprint and Sprint to Gerber will fulfill all my needs. In the past Sven and others have converted Sprint to Gerber for me, but I don't like to impose. I am hoping I don't have to download Gerber as well to do this. I have Eagle, but have been unable to decipher its use. Also PCB Express which I have mastered, and is similar to Sprint.
Serbian "Most Wanted"
Originally posted by walkman View PostHi friends,
I did draw SMW3 but not test it. So I do not want to add
if you want to test if you can add.
This is the Walkman board. The parts are not displayed, but you have a picture of the board and you can follow it.Attached Files
Originally posted by Tim View PostYes I will buy too. I have used demo version to print for etching, but I would rather professionally made boards (from ALLPCB) at AU$4-6 each, who require Gerber files, so Gerber to Sprint and Sprint to Gerber will fulfill all my needs. In the past Sven and others have converted Sprint to Gerber for me, but I don't like to impose. I am hoping I don't have to download Gerber as well to do this. I have Eagle, but have been unable to decipher its use. Also PCB Express which I have mastered, and is similar to Sprint.Originally posted by Tim View PostYes I will buy too. I have used demo version to print for etching, but I would rather professionally made boards (from ALLPCB) at AU$4-6 each, who require Gerber files, so Gerber to Sprint and Sprint to Gerber will fulfill all my needs. In the past Sven and others have converted Sprint to Gerber for me, but I don't like to impose. I am hoping I don't have to download Gerber as well to do this. I have Eagle, but have been unable to decipher its use. Also PCB Express which I have mastered, and is similar to Sprint.
SMW gut onli Serbia, Balkan. Austrelia land best ML RH relik hovk. Super 3x diskrim.
super prise pcb pcb 0.5 evro.
https://www.kupujemprodajem.com/Izra...2042-oglas.htm
pcbmilan@gmail.com
Izradjujem stampane plocice foto postupkom na jednostranom vitroplastu(1.55mm,35um). Izradjujem i dvostrane plocice od dvostranog vitroplasta debljine 1.55mm 35/35um.
Minimalna narudzbina je 300 RSD.
Obavzeno: Prilikom slanja porudzbine na E-mail potrebno je uz prilozenu dokumentaciju napisati sta je potrebno uraditi jos osim izrade jednostrane ili dvostrane plocice kako bih ste dobili cenu odmah. Primer: "Jednostrana, solder mask, busenje i stampa rasporeda,5 komada. "I dobijate ponudu za tu kombinaciju i kolicinu.
Cenovnik upit na email, ponuda:
Originally posted by blobber View PostI think you mean voilà, this is a french word for "here it is"
But where is your promised sprint layout file?
Luigi Datome vola negli Stati Uniti per giocarsi la carta NBA con i Detroit Pistons.
Luigi Datome flies to the United States to play the NBA card with Detroit Pistons.
A fine luglio vola a l'Avana, a Cuba, per partecipare al Festival della Gioventù Comunista.
At the end of July he flew to Havana, Cuba, to attend the Communist Youth Festival.
https://www.wordhippo.com/what-is/th...word-vola.html
2. no promise
MD KROT GUT OR NO ?
