Serbian "Most Wanted"
  • nice build
    • 16cm smw coils single money 50 cm deep
      nugget sens
      • Originally posted by cnckecgo View Post
        nugget sens
        Good work
        Coil sp?cifications pls
          so beautiful
          • Hello to everyone,
            • Comment
              • G?zel olmuş tebrikler
                • there is a box problem smw555 pcb 100x105mm
                  80x80mm i don't know pcb drawing 555 I want a small pcb Can you help me friends
                  • Originally posted by guvenbey View Post
                    • sorry
                      • So is the SMW v3 the final PCB (Through-hole) with the corrections? I'm trying to figure which PCB is the latest but I'm kinda lost on this topic.
                        What are the coil specifications (dimensions of RX/TX, wire thickness, inductance etc)?
                        Seems to be promising but all information is scattered.
                        • Hellow cnckecgo, please expand me which PCB version did you use, please post it and how is TX and RX inductance value, your device very deep for coins and i like it
                          • It seems to me that it is this PCB [ADJUNTAR] 53899 [/ ADJUNTAR]It seems to me that it is this PCB
                            • It is seen that it has changed some values ​​and also the position of the Zener or although it seems to me that it is a 4148. Although you cannot distinguish the Rx cap.Click image for larger version
                              • Hello cnckecgo, could you help with the configuration of the coils. I don't know which caps to use?
