Serbian "Most Wanted"
  • Originally posted by Pompey View Post
    Air tests with 555 SMW version with 27DD:
    24mm coin - 45sm
    34mm coin -55sm
    diskr -rejects all iron
    no reaction to ferrite
    very small sound cracks coused by interference
    GEB must be adjusted very fine to get best sensitivity and stability.Also coil nulled perfect.
    Hi
    Congratulations, great job, it is Caesar.
    • Super it is, but the test in air and test in the country who are heaven and earth.
        Sorry I didn't get you Orbit. Do you mean it doesn't work as well in real conditions as in air?
        • Originally posted by mindfree View Post
          Of course NOT. At ground every VLF lose 30... 50% of the depth.
            I'm aware there is some loss in depth but Orbit's comparing the difference to 'heaven and earth' which would mean very large differences.
            I am going to order parts for this detector very soon.
            Thanks!
            GEO you have a very impressive lab. I envy you
              Thanks!
              Hi.
              Make the version with the 555 at the audio. It is better and realy if you will make a good coil then you will have a very good detector.
              ohhh.... thanks for your good words about my lab
              • POzdrav za dva tona sam se odlucio bas zato da bi dobio u zemlji dobre performanse probajte trik sa cny 17 pa mi kazite a moze i neka druga varijanta kao primer na all metal odredjena boja ttona a na plemeniti metal druga boja tona
                • Welcome to two tons I decided just because to get good performance in the country, try the trick with CNY 17 and tell me a can and some other variant as an example to all metal ttona a certain color of precious metal other color tones
                  • I am sorry that a translator does not translate as it should
                    • hi all
                      • hi all
                        • Good job Gurdal!
                          How does it perform?
                            Good job Gurdal!
                            yet I could not wrap the title
                            I had a chance to experiment with the original magnum title
                            I was good.
                            I add developments
                            • again, some of us haha Srbijanac
                              • Magnum with two channels, haha.
