I have a older model JW Fishers Pulse 10 towfish.I need to build the electronics box for it as the orginal box was destroyed and thrown out(not by me)or if anyone has a old used box for this unit,ill buy it,even if it doesnt work.i can rebuild it.
Wanted:JW Fishers Pulse 10 Schematics
It would work,its just a coil.email me pics of your box like where the cable connects to the box an ill see if my cable end matches yours on your [email protected]
I have a pulse 10 box and I have a pulse 12 system. It has been a few years since I looked at that stuff, but off the top of my head I seem to recall that there are big differences. In the pulse 12, the pulsing electronics for the coil and first amplifier stage are in a little container with the fish and coil. This allows them to reduce the cable capacitance and therefor have a shorter pulse delay resulting in a better detection depth. I have an older pulse 10 box than what is currently being sold and on that unit, all the electronics are contained in the box. It might be that the newer pulse 10 separates the front end electronics as well. Good luck,
Boattow
Boattow
Thank you. I also believe that there are differences.
Well, if you have a pulse 10 for sale maybe FISHEYE could do business with you.
The pulse 10 fish an cable i have has a coax connector on the end of the cable thats 2 wire.The pulse 12 a military style connector thats 8 pin.So the coil and caable from the pulse 10 wont work with the pulse 12.
Boattow can you email pics of the pulse 10 box you have?
I finally got the jw fisher pulse 10 electronic box from a friend of mine but i still need the schematics for it as it need to be repaired as far as the speaker output goes.plus my repair tech can do some mods to it if he has the schematics for it.
Hi FISHEYE,
on eBay is currently a working Fischer Pulse 10 for USD500,- listed.
https://www.ebay.com/itm/204301625762
GeoMax
Hi Fisheye,
thanks for posting the PCB images. Is it possible to upload also an image where you can see the PCB tracks on the bottom of the printed circuit board? And it would be good to have a short list of the used IC's and transistors to evaluate the circuit better. But from the images of what I can already see is, that the JW Fisher Pulse 10 circuit is a more simple standard PI circuit.
