Chech Sabre modified
  • #91
    Yes, M1 = 100K
    Sorry, I dont have this version of PCB-B used in my detector (because it is experimental project and I am often using universal PCB for some developments) - I have another experimental pcb, so I cannot send a photo.
    • #92
      ABOUT SABRE DIGITAL (SBDG):
      First - Name of SBDG is only "Sabre Digital". SBDG is not copy of Tesoro anymore. For me it sometimes seems that I am "going" in same way as Tesoro - but there is many developers in Tesoro, I am "alone", so my steps is very slow...
      Second - now I have to make one custom PI detector with discrimination, then I will continue with SBDG.
      • #93
        Hi
        Thanks.
        My friend.
        Yes you are right!When you are alon the things happens swoler than with team work.But the inportant thing is that new Idea!
        I am shore it will work.Keep on .......................
        p.s.I ask you for this pictures because saw some from TXP and almost all the parts from PCB B were missing.
        • #94
          maybe TXP you can give some more detailed picture?
          Buy the way what is the performance of your unit?
          • #95
            Here is Google translator of my pages. Try it :
            http://translate.google.cz/translate...F8&sl=cs&tl=en
            I believe it will be better within few weeks, some translations is crazy.
            • #96
              If I don't forget that, i will take some picture tomorrow....
              I haven't momentarily sabre at home because of a changing of flat.
              On modul B I have done only a part, what is necessary for simplify function of sabre. That means a channel Disc and All (VYHODNOCENÍ in czech) and tone indication (TONOVA INDIKACE). For another experiment i haven't enough time....
              • #97
                Thanks to both of you!
                I am very greatefull.I will finish this nice unit maybe buy end of next week and will post some datas and pictures here.!
                thanks again.I am so impresed buy TGS that cant wait to see this too.
                • #98
                  Here is a picture of light version module B....
                  • #99
                    Ok!
                    thank you very much!
                    I am gonna be ready very soon too.One more question I see that you have wired speakers + to PCB B and - to PCB A and then from PCB A wire goes from - to PCB speaker - point RIGHT?
                    Also I cant see clearly how you have conected pots and switches?
                    But anyway very nice photo THANKS.
                    Can you post same picture for PCB A?
                    • Speaker is connected to the module A (in czech REPRO and GNDREPRO).
                      Pots i have only GND balance, disc level and sensitivity (all in the schematic).
                      Switches aren't necessary for first test.
                      More detailed photo i haven't not made momentarily.
                      • Hi,
                        I understand this.But will be gald to see when you can.
                        Thanks again for HELP>
