Whites Surf PI schematic
  • I want to know.
    surf pi/ must be a treasure hunt on the beach in it? Distinguish between gold and iron, how to listen to the sound?
    • Originally posted by yhl View Post
      It is not possible to distinguish between Ferro and non-Ferro targets with this detector.
      • The metal detectors, can only apply it on the beach?
        Can be in the land use?
        Sensitive to the nail. Everywhere barking. Treasure Hunt is very difficult
        What is a good circuit?
          Good circuit is those, by which you found treasure. All others circuits are crap.
          • Hello, you SURF PI had to find gold?
              If somebody hid the gold, then PI Surf Safely find gold. Best regards.
              • this is white modified.. coil 7 cm..very good for pin pointer or other aplications. regards Cristi.. 1 : http://www.youtube.com/watch?v=xiSPwBZq8es and 2 : http://www.youtube.com/watch?v=Sgb8QEhHlH0
                • hello all
                  I have great need for long PCB in jpeg format
                  if someone can help me
                  Thank you very much
                    ...this is it...works more than good!
                    Coil is 21cm in diamm.. wire 0.35, 24 windings... 1e coin detects at 26cm distance in air, loud and clear!!!
                    Hello ivconic
                    I can do to get long pcb in jpeg format
                    Thanks a lot
                    • Originally posted by bebe2010 View Post
                      hello all
                      Thank you very much
                      168 x 31 mm 1568 x 289 @ 237dpi
                      • 'Whites Surf PI, really good?
                        Stable?>
                          Stable?>
                          if your Garry's PI one is good for you then Surf PI will be also good. for you. one principle bears due same principle. such the world. if you had burn by chinese women and chinese man everybody say you that you are due chinese man.
                          • I would like to ask? Coil the smaller the better targeting?How much coil right?
                            • for "silverdog"
                              Thank you for pcb.
                              • PCB coil that goes to surf PI
                                20 cm diam, 24 turns, 1 mm, spaced 3 mm
