Whites Surf PI schematic
  • Hi, liekwang, I'll try.
    also changed the CI "CA555" (TLC555 in the original) by "NE555P" (only one found), but nothing changed, still does not work, just one "Beep" continuous.
    I do not know what to do, do you have any idea?
    Thanks.
    • Falcon,
      I had similar problem with surf pi pro and I changed from BC transistor to original 2N3906 ...
      something was not working with that BC replacement
      • ?Falcon and ndesis try to play all the potentiometer towards the left all is still sound a continuous beep and see if the solder less stick sorry my English is bad
        • Hi, sdesic, which transistor BC you used?
          liekwang, no matter how the potentiometers turning the "Beep" is the same, you say to solder the circuit again?
          • Falcon,
            it was BC557C and did not work for me.
            I know it needs to be reversed because it is different pinout from 2N3906 but it still does not work.
            I replaced with 2N3906 and it worked OK
            • I already use the 2N3906 (Q1).
              which 555 (U1) do you use?
              I use NE555P.
              My english is too bad
              • That IC is not your problem ... I have TS555, TLC555 and NE555 surf pi PRO...
                and they are working all with different sensitivity and power consumption.
                you must look for shorts on PCB - solder bridges
                • surfmaster pi v1.0.3 by SL!M 2013 ...Good luck boys
                  [IMG][/IMG] [IMG][/IMG]
                  • Your post was waiting for approval as you are a new member.
                    I have removed your other duplicate posts.
                    • Originally posted by Shahab View Post
                      Hi
                      I changed Silverdog 2-side PCB to 1-side.
                      I tried to keep Silverdog excellent design.
                      If you see some errors please tell me.
                      hi i am mehdi ho fram iran? pliz call me 09357116117
                      • Hello to all
                        I've made this new circuit
                        When the power supply is plugged in, I began to hoot
                        Please help me
                        [email protected]
                        • mehdi1199 - You only need to post your request once, and not repeat it again every few minutes. I have removed your other duplicate posts.
                          • hi to all &
                            my friend porluvr
                            can you say me is whites surf pi better than dp3?
                            how max sens in earth?
                            thank you my friend
                            • olá falcão gostaria saber o seu pi surf funcionou ?
                              • Originally posted by maxm3s View Post
