Has anyone rerouted pcb for smd? Just checking before doing it myself. Thanks.
Whites Surf PI schematic
ups! sorry! http://www.geotech1.com/cgi-bin/page...head/index.dat
NOTICE: I have no more PCBs for any of the Hammerhead projects. Please DO NOT place orders for these, because I will not be able to process your order. The GERBER files for all the PCBs are also posted below, so you can have one made if you wish. Some PCBs may be available from "Silverdog"... see the forums for more info.
Originally posted by DIRCEU View PostHi! CORDIUS
Many thanks.
I made SURFMASTER apberg's version and I used IRF9640.
Best Regards
DIRCEU ZANELLA
my first post and i want to ask if someone can post the correct schematic and pcb for thiw project...i hear good results!
i made the lucas pi with good results and i want to make surfm...
please be sure for schematic and pcb please or some mods...
thank you for your time guys
Question: This may be covered elsewhere, if so please advise. I did a search and came up with coil shielding info. I want to enclose my surf pi 1.2 in a 2" ABS pipe. Have it pretty much planned out, and looks good. However, as it is plastic, should I worry about case shielding to reduce possible EMI? If so, would a graphite paint around the outside work? From searching, this is probably not a significant problem.
Secondary question: Must the PCB be grounded to the external shield?
TIA
do not despair there at the end of the tunnel start your work with that
http://md4u.ru/forum/download/file.php?id=10588
Originally posted by maxm3s View Postdo not despair there at the end of the tunnel start your work with that
can you upload the pcb at jpeg format with correct dimensions please???
this pcb working 100%
all you need attached
print 1:1
surfmaster2.pdf
surfmaster1.pdf
surfmaster3.pdf
surfmaster4.pdf
surfmaster5.pdf
