Whites Surf PI schematic
  • Has anyone rerouted pcb for smd? Just checking before doing it myself. Thanks.
    • for WHAT? Carl has a batch of boards on HAMMERHEAD-PI. their price is VERY LOW.
      • ups! sorry! http://www.geotech1.com/cgi-bin/page...head/index.dat
        NOTICE: I have no more PCBs for any of the Hammerhead projects. Please DO NOT place orders for these, because I will not be able to process your order. The GERBER files for all the PCBs are also posted below, so you can have one made if you wish. Some PCBs may be available from "Silverdog"... see the forums for more info.
        • Silverdog still has them.
          http://www.silverdog.co.uk/shop/inde...&product_id=74
          • Originally posted by DIRCEU View Post
            Hi! CORDIUS
            Many thanks.
            I made SURFMASTER apberg's version and I used IRF9640.
            Best Regards
            DIRCEU ZANELLA
            hi there...
            my first post and i want to ask if someone can post the correct schematic and pcb for thiw project...i hear good results!
            i made the lucas pi with good results and i want to make surfm...
            please be sure for schematic and pcb please or some mods...
            thank you for your time guys
            • its all in this very thread!, search the thread, better still READ THE THREAD.
              i'm not trying to be rude, and i understand its a long thread but sheesh.
              • i read the most of this thread but im comfuse with all post...
                please the single side pcb and parts list
                please help to find the edge
                • Originally posted by bisba View Post
                  someone please
                  • Question: This may be covered elsewhere, if so please advise. I did a search and came up with coil shielding info. I want to enclose my surf pi 1.2 in a 2" ABS pipe. Have it pretty much planned out, and looks good. However, as it is plastic, should I worry about case shielding to reduce possible EMI? If so, would a graphite paint around the outside work? From searching, this is probably not a significant problem.
                    Secondary question: Must the PCB be grounded to the external shield?
                    TIA
                    • do not despair there at the end of the tunnel start your work with that
                      http://md4u.ru/forum/download/file.php?id=10588
                      • maxm3s, if your reply is in answer to mine (case shielding), I cannot open that type zip file.
                        • Search for 7zip unzipper program
                          • Originally posted by maxm3s View Post
                            thank you my friend...
                            can you upload the pcb at jpeg format with correct dimensions please???
                            this pcb working 100%
                            • all you need attached
                              print 1:1
                              surfmaster2.pdf
                              surfmaster1.pdf
                              surfmaster3.pdf
                              surfmaster4.pdf
                              surfmaster5.pdf
                                print 1:1
                                [ATTACH]27855[/ATTACH]
                                [ATTACH]27854[/ATTACH]
                                [ATTACH]27856[/ATTACH]
                                [ATTACH]27857[/ATTACH]
                                [ATTACH]27858[/ATTACH]
                                thanks a lot friend...
