Whites Surf PI schematic
  • I'm having problems with the surf pi not the same sound in speakers
    • and which function in the circuit NE555
      • i guess ne555 is for pulse timing
        • it interferes with the sound of the detector
          • Originally posted by nando.22 View Post
            That's a very sensible statement.
            Did you use NE5532 instead of NE5534?
            • scheme of link potentiometers
              • Rode another pcb more the problem is still not present in the audio speaker and this warming NE555
ID:	335051Click image for larger version
ID:	335052Click image for larger version
                  • al the photos of this coil and pcb a very low coil
                    • which function in the circuit ICL7660
                        The ICL7660 is a voltage converter. In the Surf PI circuit it is used to generate the -5V supply for the opamps.
                        • my surf pi was working now so keep the sound in the earpiece and not ten potentiometers variation which can be
                          • correct voltage terminals ICL7660
                            • how to adapt in an amplifier output surf pi
                              • can i put 9volt battery in SURFXX board
