Whites Surf PI schematic
  • ?Surf pi Board long print layout arberg I get sensitip in 9 cm gold rings and coins almunium. Size 2, 5 cm aerial just get sensitive distance 20 cm diameter 9 cm coil and wire 0, 5 mm 24lilitan what should be modified in order to reach a depth of 30 cm please me greetings from indonesia
    • ?What Influences when the voltage the current Fed's surf pi 12 volts dc 3.5am
      • Originally posted by liekwang View Post
        24lilitan << 24 round
        • I only have experienced with a coil, 9.5 "(23 cm approximately), 20 turns of magnet wire gauge AWG 24 (0.64 mm) and the maximum distance for a coin of 2.5 cm diameter is 28 cm. According to data in this forum, the sensitivity and depth of detection of 28 cm., it is acceptable for the surf pi.
          Maybe you can turn the circuit more sensitive, by turning the sensitivity potentiometer completely to the right, but the circuit becomes unstable.
          I do not use a radial coil, like the picture of Dimovnis, my coil is only 20 turns with a 9.5" diametes very tigth.
          to get more depth in your circuit, you can tunnig the delay potentiometer slowly,and test the sensitivity, to reach the maximum.
          • paku
            ?Thanks spike but up to now I experienced every Rod MD I swing to the ground there will be noise like there is metal under the coil I have glue with hot glue so that power is not rocking yet still every coil touching the ground there will be sound like there is metal
            • escarabajo
              up to now my 20 cm diameter of the coil wire 0, 5 mm I testt with gold ring 3gram get 20 cm aerial but my MD stick swinging right to the right or to the left and close to the ground or touch the ground with the head coil there will be sound like there is metal and I try elsewhere kept the voice of false signals
              • Can somebody please upload the latest SurfPI 1.2 PCB schematics circuit diagram and components that has been tried and found working and confirmed that there is some minimal depth achieved.
                • Hello everyone!
                  In my SurfMaster, is just a "biiiiiiiiip" continuous, with or without coil (18 turns, 0.6mm wire, 20cm diameter, 1 Ohm, I do not know the inductance);
                  When step inside a metal in coil the "biiiip" is stronger (as if detecting)
                  Adjusting Offset got - 0V on pin 6 of the NE5534
                  The tune does not work (the 10K potentiometer is working);
                  the delay hardly changes the sound (just a little more serious acute or more), only the volume works right, I'm using a Pieso.
                  The IRF9640 heats up a bit, depending on the settings of the potentiometers.
                  In ICL7660S - 8 pin + 5V and pin 5 to -4.45 V,
                  The voltage at pin 3 is CA555 + 9V
                  In 2N3906 between the collector and the GND is 12.75 V,
                  My PCB is the same as the link Download - (http://www.geotech1.com/forums/showt...hematic/page21) - post - 509
                  The measurements were made with a multimeter, indoors.
                  I need help, I do not know what to do.
                  Sorry the translation.
                  • Termine el Surf PI y funciona a la perfeccion, muchas gracias a todos los que aportan con los esquemas y mejoras. Mi bobina de prueba es de 20cm de diametro, 18 vueltas y 0.5mm y detecta una moneda pequeña a 25cm, espero mejorar mi bobina y alcanzar unos 30cm. Estoy muy feliz con los resultados. GRACIAS!!!
                    • One more detail, my coil is 0.9 V, and the wire is 23AWG.
                      Can anyone help me?
                      I thank you in advance!
                      • hi halcon, your detector dont work? plaese you can upload image the circuit (2 side)? sorry my poor inglish xD. or send me email [email protected] whit atached image.
                        • 04-29-2011, 12:20 PM post 396 and 04-29-2013, 1137 PM post 679 look and explain 2N3906 E, B, C. ...?Click image for larger version
ID:	336994Click image for larger version
                          • Hi blizi.
                            My detector, does not work, just keep beeeeeeeeeep.Click image for larger version
ID:	336996Click image for larger version
                            more pictures in email.
                            • I finished assembly surf master pi PCB's oxygen007 but you adjust pin 6 ic 5534 to 0V speaker sound is continuous, by adjusting the threshold to sound termination I have no sound in headset when approaching the metal coil but on pin 6 is change the value to -0.20V when detection is.If you set pin 6 to -1.50 V, the metal coil close to 3 inches, the speaker begins to sound. this is the only way it works.what is the problem?
                              • ?Falcon what ye coaxial cable to the tv, antenna, if possible replace with copper wires do not exist paradai
