Whites Surf PI schematic
  • hi Qiaozhi
    can you show me a good gold detector in this site that i can build please ?
    I think tesero golden saber is good ,what's your idea?
    thank you my freind
    • Originally posted by alonejax View Post
      hi Qiaozhi
      thank you my freind
      Where are you planning to search for gold? In-land or at the beach?
      And what are you searching for: small jewelery, gold nuggets, gold statues?
      • Ainda não, vou substituir alguns CIs e Transistores. Você fez algum?
        Not yet, I will replace some transistors and CI. Have you made any?
        • thank you qiaozhi for replay
          planning is mountain and f0r small & medium nuggets
            In that case you need to decide whether an all-metal detector (such as a PI) is suitable for your application, or whether you need to discriminate against iron. If you decide on a PI, then you will need to construct a fast coil in order to detect small gold nuggets.
            • ok my friend
              what's your ideal pi ?
              thanks
              • Encontre esta moneda de dolar con mi surf pi, alguen conoce esta moneda? se que es un dolar por lo que se puede leer, pero alguen sabe algo mas de esta moneda?(encontrada en Chile)
                • hi.. if i want to use 2 pcs 9v battery instead of 8 pcs 1.5 v.. can anyone show me the modification needed to do this.. thx..
                  • The depth of this detector with loop 1*1???
                    • Originally posted by starmoml View Post
                      The Surf-PI has a self-adjusting threshold, so you need to keep the coil in motion. This will be difficult with a 1m x 1m coil.
                      • Originally posted by blizi View Post
                        [ATTACH]25827[/ATTACH]
                        [ATTACH]25828[/ATTACH]
                        Translated in google
                        "I found this dollar coin with my surf pi, alguen known this coin? is that it is a dollar that can be read, but alguen know something more about this coin? (found in Chile)"
                          Surf PI has a modification to non motion, but 1m x 1m...
                          • ok.What is the maximum depth of the metal detector(surf pi)to a metal object 50 * 50 cm????
                              The question you ask is like asking how long is a peace of string because its influenced by ground conditions and whats going on around you, some detectors handle heavy minerals etc better than others, so in affect one machine could perform better in one field and the other in the next field to it
                              Pumping up sensitivity with modifications to show better detection in air tests may look impressive to the novices but in real use you can actually end up with something that is near useless which I well proved with some of the modifications with the TGSL project many moons ago that were getting banded about, I have also proved it with many manufactured detectors over a period of time.
                              The only way to compare machines is have them working in the same location, detecting the same target in the same spot in the same ground, and that only proves that one machine worked better in that particular location on that type of target in those particular weather conditions on that particular day
                              Unless of course your trying to locate objects in the sky.
                                Once more, build delta pulse. Surf is completely unsuitable for detecting large objects deep and for large coils\frames, like 1x1m. It is designed for beach hunting, coins, jewelery, etc, with 20-25cm coils, with relatively slow sampling delays to ensure operation in salt water. With some modifications, faster coils and sampling, increased gain etc, can be fine for small gold too, but lacking ground balance, so can be problematic in most gold fields. Also, it is strictly “motion only” detector, useless with very large coils. Can be modified for static, but pulse parameters are not tailored for large and deep targets. Right tool for right job. Delta is simplest DIY solution, exactly made for this purpose. Forget ground balance, not relevant here, with large coil and slow sampling, ground signal will dissapear long before detector can measure it, pulse parameters are OK for large stuff, depth for 50x50cm with large coil is, well, more than you are willing to dig. For surf, with 25cm coil, something like 1.2m or so, depending on coil and adjustment. For delta issues, best to consult someone with more experience, like kt315 (aka 2N5551) for example.
