Whites Surf PI schematic
  • test done on the beach
    • <imgsrc="http://farm6.staticflickr.com/5546/1...5335de9a_b.jpg"/>
      [IMG src]http://farm6.staticflickr.com/5546/1...5335de9a_b.jpg[/IMG]Check out my Pipe PI monster. Pots are under watertight screw caps so is a phone jack. When jack not used led lights up instead so you dont need headphones underwater. I made it to be able to snorkel with it and look for cool stuff in carribean sea The only thing that needs to be sealed is a nozzle where wires coming out of. I thought that someone might like the idea of using ABS or PVC pipe and decided to share it. Let me know what you think. Used Surf PI 1.2 in 1-1/2" ABS pipe. First barrel holds pots and pcb, second barrel holds batteries and phone jack. Not the lightest design but for starters will do
      • http://farm6.staticflickr.com/5546/1...5335de9a_b.jpg Check out my Pipe Monster PI Used ABS pipe from home depot. Made for snorkeling and to be abused. All pots are under screw caps so is phone jack. Has external led to be used underwater without headphones. Just thought someone might like the pipe idea and decided to share. Let me know what you think.
        • was very good captain art3000 to envy me if you have a good depth, send me your project with pvc
          congratulations maxm3s
          • I get around 28-30cm on mens golden ring. I think its enough. I really dont want to dig deeper under water.
            Soda can at about 60-70cm. Whats up with yours? I did everything by the scheme and partlist. Pcb kit from Silverdog.
            • Ha, ha . . . Silverdog could never have imagined this guy:
              http://www.youtube.com/watch?v=ez3lbh0sSzA
              http://www.youtube.com/watch?v=NlN9rDqzN4Q
              • Over the top. At least, guy is not in shortage of speaker wire, so he did proper coil,(according to my posts here) we will see outcome...
                • Hello all
                  Why the difference?
                  Error? or different configuration?
                  • Hello Hawk
                    • hello hawk this is the correct layout to use
                      • Do you have one in lay or pcb or bw format?
                        Thanks!
                        • Originally posted by maxm3s View Post
                          [ATTACH]27247[/ATTACH]
                          thanks maxm3s
                          • OMG!
                            This guy is hilarious! Here is video showing results of his build. http://www.youtube.com/watch?v=lD4wpSObYFQ
                            WARNING, there are a few bad words, to say the least. But highly entertaining, and probably expresses more than a few frustrating moments many of us experienced with this build. Stand by, he will try again!
                            • i need pcb to print it
                              can any one send it here ( correct pcb and no image )
                              thanks
                              • here are the files pi Surfmaster
                                http://md4u.ru/forum/download/file.php?id=10588
