Whites Surf PI schematic
  • Originally posted by Aiko View Post
    Did you make this PI? Even I touch the ground (minus on the batteries) it follows a beeping sound.
    Regards!
    I have not made this PI, but not grounding the metallic case is a common problem. I assume you're not actually touching any of the circuit components to cause the beeping?
    Perhaps you simply do not have enough decoupling caps fitted.
    • Thanks Qiaozhi! Even I touch the minus on the batteries it follows a beeping. Or, If I turn some of the potentiometers even through plastic knob. I think, if I have a metallic corpus (in my case it is plastic) even then if I touch the corpus will follows a beeping.
      To all – please excuse my English!
      Regards!
      • try to invert the two wire of the coil, in your photo the red wire with the ground wire of the coil.
        • Thanks for the idea Cordius, but not difference. Anyway – Surf PI works very well. If there was a discrimination, it was going to be a dream.
          • Oi Dirceu SM PI
            Oi Dirceu
            Sou de Portugal/Lisboa , já sei que és de São Paulo, tenho estado atento a este projecto, tens sido fundamental no desenvolvimento do mesmo. Se puderes manda a tua placa e a informação que tiveres para o meu mail real5050@gmail.com , desde já obrigado.
            Abraço
            José Real
            • SM PI Cordius
              O Post anterior era para ti Cordius , peço desculpa, tu é que tens sido fundamental no projecto , e ainda bem que assim é, se puderes manda, tá no post anterior o meu mail, desde já obrigado.
              Abraço
              JR
              • hello Real5050
                please write in english !! I dont' know your language.
                • Hello Cordius
                  I Make a great confusion , I no why, I think you are brasilian, because Im portuguese, the same language, but in my post i say basicaly you are done a great job. I ask if you make send your board to my mail, in advance many thanks
                  all the best to you
                  JR
                  • Surf PI PCB
                    Hi guys,
                    Do any of you have a working PCB diagram for the Surf PI in either a GIF or JPG format that you could post here please?
                    I cant download the Sprint viewer due to restrictions on the computer I use so the layout files are of no help.
                    Would really appreciate any help.
                    Thanks, Jim.
                    • Hello
                      I attached Apberg's Long Pcb in Pdf format .
                      Erol
                      • Front Side of Pcb
                        • Originally posted by erolunall View Post
                          Hello
                          Erol
                          it's a single side pcb?
                          thanks for the second pdf file
                          • part placement
                            • Thanks
                              Hi erolunall
                              Thanks very much for the files you have posted. I have managed to download Sprint and after working around the printing restrictions on the free version I have printed and etched the board from the layout file posted by Apberg.
                              I can confirm that this PCB / detector DOES WORK VERY WELL. Many thanks to Apberg and others for sharing their work - thank you guys.
                              I am just a day or two away from having this detector ready for use at the beach, will post some pics when its finished.
                              Does any one know what the modifications are that Mr Bill makes ???
                              Regards, Jim.
                              • Hi Cordius, i was looking for your one side pcb for surmaster detector, but now i cant find it on the forum. If i m not wrong, i bealive you made it on sprint layout software. If so, can you send it to ce3llp@mi.cl
                                In advance, many thanks
                                Nelson
                                Originally posted by cordius View Post
                                yes, pulse frequency
