VLF MD (by Sascho - Varna)
Hi scs,
I have a small request, and a comment.
I wish to use this kind of coil compensation in my future designs, and I am aware that this is not a new idea, yet you are the one promoting it, so... Is it OK by you if I use it?
A comment is about the Tx oscillator. In my sims of a balanced oscillator, and your oscillator IS a perfectly balanced one, I found that adding capacitors in the base circuitry moves a phase in way favourable for off-resonance oscillators. Your capacitors are at 10nF, which is on the safe side, but the effect is still there.
- Likes 1
Of course. My goal is obtaining nice noise figure by direct method, coupling a coil directly to a real low noise preamp, and that would provide a very monotonous phase change there. Even a series resonance in this configuration has a very little and monotonous phase change.
There are many ways of achieving superior noise to mid range op amps.
This is the way that was connection to the transistor and search coil .If you have a better idea, I will be glad to Correct picture attached.
GreetingsAttached Files
Good afternoon, I looked through all the pages of the topic and there is not a single publication of the board in LAY, here, please, please check, maybe I put something wrong in the denominations, the pinout of the transistors. If there are errors, please correct them. is it worth adding to the board?Attached Files
