Four Transistor Metal Detector
  • Four Transistor Metal Detector
    For full article read Nuts & Volts Vol.29 No.2 - February 2008
    Build A Four Transistor Metal Detector
    Want to be a treasure hunter? By discerning subtle changes in frequency, this design is capable of detecting coins to a depth of three to four inches.
    The circuit can sense a soda can at a depth of six inches and metal pipes at an even greater distance. The unit is powered by two 9V batteries in series. The detector has a current draw of approximately 9 mA at 18 VDC.As a result, the batteries should last a long time.
    Theory
    The design consists of four parts:
    1) Q1 forms an oscillator whose frequency is determined by L1.
    2) Q2 is a reference oscillator whose frequency is set by C6.
    3) Q3 is a mixer that multiplies the outputs of Q1 and Q2.
    4) Q4 is a simple one transistor amplifier.
    L1 needs to be 100 µH. This inductor is created from 22 turns of 22 gauge magnet wire on a four inch diameter coil form (see Reference 1). However, I wound the coil with 21 turns, resulting in an inductance of 88 µH. The inductance measured into the phono cable with the search coil connected is 126 µH. In order to work properly, you must use the audio cable specified in the Parts List. The resonant frequency is F = 1 / (2p*SQR(L1*C)). C= 1 nF in series with 10 nF + 56 pF. Solving yields C = 965 pF. Calculating for F gives 456 kHz. Therefore, the oscillation frequency of Q1 is 456 kHz when no metal object is near the coil L1.
    PARTS LIST
    R1,R4 15K 5% 1/4W
    R2,R5 33K 5% 1/4W
    R3,R6 1K 5% 1/4W
    R7 ,R11 100K 5% 1/4W
    R8,R13 4.7K 5% 1/4W
    R9,R10 47K 5% 1/4W
    R12 100 5% 1/W
    R14 1M 5% 1/4W
    R15 2.2K 5% 1/4W
    R16 5K audio taper pot
    C1,C7 100 nF 50V ±10%
    C4,C9 10 nF 50V ±10%
    C3,C10,C13 1 nF 50V ±10%
    C2 56 pF 100V ±20%
    C8 470 pF 100V ±20%
    C5,C11,C14-15 10 µF 50V ±20%
    C12 1 µF 50V ±20%
    C6 15-150 pF variable cap
    L1 See text
    L2 100 µH ±5%
    Q1-Q4 2N3904 transistor
    J1 RCA jack
    J2 3.5 mm phone jack
    S1 SPST switch
    Aluminum sheet K&S Metals
    Wood slats Forster 6-Count Slats
    PVC pipe 6’ 7/8” OD PVC Pipe
    Audio cable 6 ft cable
    Case 6 x 4 x 2
    Battery snap 9V snap (2)
    Earpiece Ceramic earphone
    PCB Prototype board
    Battery holder 9V holder (2)
    Tape Two-sided adhesive tape
    Batteries 2 x 9 VDC
    Theory
    PARTS LIST
    R1,R4 15K 5% 1/4W
    R2,R5 33K 5% 1/4W
    R3,R6 1K 5% 1/4W
    R8,R13 4.7K 5% 1/4W
    R9,R10 47K 5% 1/4W
    R12 100 5% 1/W
    R14 1M 5% 1/4W
    R15 2.2K 5% 1/4W
    C2 56 pF 100V ±20%
    C8 470 pF 100V ±20%
    C12 1 µF 50V ±20%
    L1 See text
    L2 100 µH ±5%
    J1 RCA jack
    S1 SPST switch
    Case 6 x 4 x 2
    PCB Prototype board
    Batteries 2 x 9 VDC
    interesting shem, what about sens......
    .....you must to put stabilizatory
      I am amazed!
        WAHEY FOR good old BFO. Oh how that takes me back to the REAL days of detecting.
          Nice one;
          Here it is in PDF
          DOWNLOAD 17MB
