Full m/lab SD2000 schematics
  • i want to try sd2000, have you pcb file?
    thanks a lot
    • Selim, you wouldn`t happen to have board dimensions of the power board, your image posted on page 9 of forum http://tinypic.com/r/2qjem2r/4
      • thanks selim
        • Hello,
          Has anyone built the SD2000 using this PCB design? If so, are there any issues?
          Thanks in advance!
          Brian
          • SD 2200 D Minelab
            Originally posted by aft_72005 View Post
            Not work
            Hi
            Nice to found you here.
            I´m interested to make one large coil 1x1m for my SD 2200 D Minelab pulse induction,do you know if it is possible ?
            • Originally posted by Morgan View Post
              Hi
              Hi Morgan
              I didn't build large coil for SD 2200 yet , for other type PIs yes.
              But base on theory, yes.
              Please act as I say , measure original coil inductance and resistor , then equal and extend
              This parameters to big coil .
              Best regards.
              • Minelab SD
                schematic was remade by Vladimir. enjoy
                Hi
                Do you have information for building BIG COIL for SD 2100 ?
                  Hi
                  Hi Morgan,
                  it is possible, but very rare done, because on heavy (mineralized) terrain it come out too noisy. Ask Mechanic on next (LM394 ....) topic.
                  • SD 2200 D Minelab
                    Hi Morgan
                    Best regards.
                    Hi
                    Some years ago i saw for sale very big coil for SD,the name ZULU-SHIELD,maybe 1,5mx60cm,but now i cant find this coil for sale,so i want to build,but nobody here know how to make this ?
                    I have the 50 cm concentric coil but still catch iron nails from depth 40 cm,so i need biger coil to avoid small objects.
                    Should i open one of my smaller coils to see inside ?
                    Seems dificult,coil cable as five pins,each one measure between them 4.5 ohms...
                    Do you have some information about MINELAB SD coils ?
                    • COIL for SD
                      Hi Morgan,
                      Thanks,but maybe dificult project for me,i think my option is to buy 2hand ZULU-SHIELD...
                      • Hi Morgan,
                        For a Mono coil for a SD you require Inductance around 300 uh and resistance of .4 ohms you might have a problem finding the correct wire if using Litz type wire you would need something around 36 strands of .2 mm solder through enameled wire but you may need more strands to get the final required resistance and try to keep your shielding at least 8 mm from the coil bundle you can PM me if you like what model SD are you building for as a SD2000 requires a coil with higher Q than the others.
                        Regards, Ian.
                        • SD big coil
                          Originally posted by IBGold View Post
                          Hi Morgan,
                          Regards, Ian.
                          Ian thanks for this precious information .
                          I have the model SD 2200 D,this model can use the same coils as the older model SD 2100. I want to build a square 1mx1m coil for my SD. The largest coil i have is the concentric 47,5 cm,and detect one iron nail more than 40 cm underground,i want to avoid this small rusty targets using larger coil (cant find nothing in the market,zulu-shield large coil not available).
                          Now i need to know connections between coil and the five pin in the cable,i imagine PI simple coil like BFO we need only two or three pin,but why need five for SD ? Do you have some more imformation ?
                          • Hi Morgan,
                            In DD configuration connections as follows.
                            Pin 1 is RX shield and linked in the plug to pin 5.
                            Pin 2 is RX active.
                            Pin 3 is linked in plug to pin 4.
                            Pin 4 is TX active.
                            Pin 5 TX shield.
                            In MONO configuration.
                            Pins 1 and 5 linked and pin 5 connected to coax shield.
                            Pins 2,3 and 4 linked in the plug and pin 4 connected to coax center conductor use 1.0mm for the links hope that helps you.
                            Regards, Ian.
                            • SD 2200 D Minelab
                              Hi Morgan,
                              Pin 2 is RX active.
                              Pin 4 is TX active.
                              Pin 5 TX shield.
                              Regards, Ian.
                              now i understand
                              thanks
                              • Glad I could be of help.
                                Regards, Ian.
