Full m/lab SD2000 schematics
  • Hi Mick
    Thanks for the tip. Will be heading up to Creswick this week and will try tuning it there. Next door neighbour has a 2 meter diam. satelite dish which I think plays havoc on my other detectors too.
    • Can someone post PCB file?
      Detecto
      • http://depositfiles.com/files/e2b9wzfj3
        • Thank you kt315!
          Detecto
          • Thanx Zed
            Great job Zed. Very generous!
            • aloha from gs And congratulations It's unbelievable WELL DONE.
              exists replacement for tlc 074 and ca 3083 Because I can not find In my country.
              please for your assistance. I WILL DO pcd without smd .
              • Hi all.
                Someone made ​​this project?
                Difficulties?
                Working well in search?
                Lucafa
                • hello Could you explain the Prices the two diodes at power supply, not displayed . THANK Sixthly beforehand.
                  • I would like your opinion. SINGLE FACE PLAQUE ..
                    I have not yet completed ..
                    • g.s.
                      What shematics use?
                      I've seen some of them with errors.
                      Lucafa
                      • USE schematic from the zed
                        • FOR TO ALL. FINISH PCB BY G.S. WHEN WILL UPDATE THE PLAQUE ASSEMBLY AND DO TESTS
Name:	SD2000 BY G.S.JPG
                          • Good looking board g.s., keep your work.
                            Is this surface mount or trough hole - pictures isn't really clear?
                            • I have to make SOME corrections and will publish here with better resolution, WM6 BELIEVE TILL TOMORROW to finish
                              • here are with good resolution. you can choose for any errors
                                I would happy if I had a little help.
                                Acknowledgements G.S
Name:	SD2000  1.11-page-001.jpg
ID:	335089Click image for larger version
Name:	SD2000  1.22-page-001.jpg
ID:	335090Click image for larger version
ID:	335085Click image for larger version
