Full m/lab SD2000 schematics
  • Any idea how the resistance of the inductor 150uh in the power supply ?
    • Can you replace transistors vn2410l with bsn274,zvp4105 with bs250?
      • Hi N@SKO Qed preamp try
        • Originally posted by N@SKO View Post
          i would think you can use just about any n channel fet but it does need to have a fairly high voltage rating
          • hello friends
            i want to learn first GB pulse is N10 and second pulse N9 ?
              i have used bs250 for the p channel fet and it works ok note that the published circuit has the fet in backwards
              • Originally posted by ashkelon View Post
                hello friends
                i dont understand your question
                • please can you explane me how ground balance circuit work
                  • I'm looking for sd2100 tx and sample pulse timing .Thanks in advance!
                    • This is FBS Tx, and 2100 is a PI with some silly timing scheme not shown in this picture. Good news is that both patents for FBS and silly timing scheme of SD series are expired, so have fun copying.
                      • What he shows isn't FBS, it probably is sd2100.
                        • I am surprised that we have not seen a release of modernised SD2000 detectors considering the GB patents have expired.
                          • Indeed.
                            On a related topic can anyone assist with an equivalent replacement for the ZTX688B?
                            • FZT688B use ok
                              • haaa haaa
