When Ground balanced - most probably it is drifting from time to time? Isn't that so?
It is probably also pretty sensitive to temperature changes? Drifting again?
It is probably early '80 or late '70 model?
So if you still like it and want to hunt with it, you can make significant improvement by applying Faraday shield on that coil.
Since it is concentric - it is more advisable to make shield by spraying it with graphite powder spray than to apply Al foil tape (more easier).
There is a VLF/TR 950 for sale quite cheaply - would it be worth buying? The manual states 10" depth for coins for the all metal CS220. It has a DD coil, so that might be a good candidate for my non-motion detector?
If it is cheap than it is worth to buy.
That is the old one, probably you will not be thrilled with it's performances.
But at least you will enter the non motion world with it and see what is all about.
I am a CScope dealer, if ANYONE wants one, please PM me I will do them a VERY good price (ALL models).
Admin, if this post is considered inappropriate, please remove it!
Hi Sean
Looking for the a instruction book and coil specs plus circuit diagram for the TR990D the site has for the 950 which looks the same but would be nice to have the proper one.
It works fine just like to see circuit configuration plus i like to make a better coil for it.
Many thanks in advance
@Sean_Goddard :
I've got a cs660 and I'm looking for the schematic and any others informations (Coil datas, tweak, ...) about it.
I already got the user manual.
What can you do for me ?
Hugo
Saludos a todos, tengo un Metadec1, y necesitaría una bobina, también si se dispone del esquema del mismo, así como de la bobina, esta es de DD. A que frecuencia trabaja dicho equipo, ya que en el manual no lo ponia, en fin, tengo un buen aparato que no funciona por la bobina, y no le vale cualquiera, supongo que si no le metes la frecuencia exacta, no va, intenté porbar con la del newforce R1, y nada, os agradecería información al respecto. Gracias. Atte. Foxtrot
Hola Foxtrot,
los datos de las bobinas son las siguientes: 11.38 ohm / 1,987 mH y 8.32 ohm / 1.962 mH.
Los mismos valores en DD bobinas.
Puede ser que hay componentes internos en bobinas R1?
Saludos!
I have some troubles reading the schematic, can anyone confirm the frequency this rig operates at, and where are D1 and R12 connected?
Otherwise, I like the way phase is set by Johnsons counter and a PLL. TGSL uses delay instead, and here is the phase extracted directly. I thought of this concept as a delay mechanism for PI as well.
