Fisher Gemini Schematic
  • Fisher Gemini Schematic
    Hi, I Have A Fisher Gemini Two Box Detector Probably The First One Made It's Not The 2 Or 3 Model. I'm Running It With One Nine Volt Battery In The Transmitter And One In The Receiver.. It Only Shows About 80% On The Battery Test On The Receiver And About 80% On The Transmitter. I'm Using A New Battery And Have Tried Other Batteries. My Question Is Does Anyone Have A Schematic For One Of These Units. Or Does It Run On 12 Volts? I Know I Could Use 6 AA Batteries And Get A Better Longer Lasting Nine Volts.. But I Need To Have A Schematic Or Manual Etc. To Know The Proper Operating Voltage Etc....I Would Like Some Info And Schematic If Anyone Has Any.......Thanks
    PCB pictures
    Send me detailed PCB picture to see what is your model.
      Fisher Gemini
      Hi, This Unit Is Just Called Fisher Gemini. I Assume It's Model Number One. It Uses Three IC's In The Receiver A CTS7521,CA3046,MC3401P And Two Transistors 2N3638A.. If You Have A Schematic With Them Parts On It Then That's Probably The Schematic....I Have The Gemini Two Schematic But It's Different......Thanks
