Radio Shack
  • #46
    Originally posted by amtech2005 View Post
    Radio Shack
    The correct Radio-Shack model number should be 63-3006 or even 630-3006. If this model uses 3- 9 volt batteries , and you have ferrous-non ferrous on your analog meter it is a 63-3006 !!! If it uses 6 AA batteries it is another model.......So the model number 63-3003 , I posted above is wrong !!!!!!See the little notepad with the correct specs , and sorry for my earlier error on the model number.
    Esteban ,After you solder the new inductors in place. With the batteries not connected turn on the unit , then all the controls mid-range , take an ohmeter reading with your DVM across the battery terminals , make sure nothing else is shorted before you re-apply power. As you can see the specs say 30-35 milli-amps is normal , anything much higher is not good. Anyway, you also have Excellent electronic troubleshooting knowledge ,so you will not have any problems repairing this Detector............Eugene
    Thank you for the table with the characteristics of this device.
