Fisher 1266 PART 1
  • #46
    Hi Sean,
    I could be interested too in cloning device MD303 (or make mods on a factory made one)... what about say detection of 1eur (on air) on good tuning and what about coil dimensions ?
    Kind regards,
    Max
    Sean made a typo in his post - it's an MD3030, not an MD303.
    The coil is a 245mm diameter concentric.
    http://www.pulsar-electronics.co.uk/...Field_Test.pdf
    • #47
      Fisher 1266 PART 1
      Wow , very impressive , AVAILABLE CHRISTMAS 2005 !!!!! I HAVE BEEN ASLEEP for 2.5 years , this is the first time I saw this one , and I check the "Chinese Trade" websites frequently...........Thanks for posting Qiaozhi !! Is this the one that is very similar to Fisher 1266x ?? ..............Eugene
      P.S. Everyone read the post right before mine . Field Test PDF
      • #48
        Apparently so. I will shortly be dismantling this detector for back-engineering.
        • #49
          Hi All, sorry about the missing field test I just cleared out my website folder for something else and didnt see this post before I did.
          • #50
            Thank-You Max for posting that GC-1030 Brochure and everyone who posted on this thread !! Maybe we will see all the data on a field test Soon ! You know the Chinese will eventually build that top of the line Detector similar to the explorer or the DFX at a much lower cost , when ? we do not know !! I give the Chinese credit for the improovement over the years on their detectors !!! Now , the second subject which really bothers me !! And I am going to get "some" very negative feedback on this , But I am 100% right on what I am about to say !!! Before I make my comment: Sascho in Bulgaria , Your work is Excellent , I have no complaints about your designs , or anything at all , against Bulgaria !!! But who the heck reverse-engineered and made the schematic of the Minelab Relic Hawk , and why did they invent the coin-seeker pro . I think it is a slap in the face to Metal Detector builders all over !!! I am sorry to make this statement , but it has cost me wasted time and money . Not a big problem , I will finish it later when I find a cheap Relic Hawk for sale , no big deal !!! If someone claims they are an Electronic Technician then act like one , If a reverse-engineered schematic is not correct , then post on the schematic "as a Courtesy" , this schematic may contain errors and may not be complete . Write it on the schematic !!!!! It is called "Honesty"......... Once and a Great while a complaint is posted here on Geotech ....Good complaints are welcome here "occassionally" I hope I recieve some good feedback on this , hopefully not all BAD ??? ...........Take care everyone........Eugene
            yes... there are probably mistakes there... and, last, the schematic have lot of missed ic labels... so we guessed to find a solution.
            I think that the big problem at RH is not only the lack of a perfect schematic from accurate reverse engineering but also that coil required is probably much more complex issue than on other VLFs.
            Now... device works at 95% as in schematic: the really big problem is a bad tolerance to iron stuff when at far distance... you can get e.g. a signal from a large nail at 30cm and waste time and efforts trying to dig it like a good target.
            The other big problem we have is that no comparision has been made between my version of PCB+coil and others... that stalled even more further development. If you sum with the fact I'm doing other things at now... and have few spare time... you'll see why we are not going ahead on the topic.
            The bulgarian folks made CoinSeeker cause wanna a reduced circuit, simpler and effective... but , you know, sometimes, though good intentions, results are not so good.
            Kind regards,
            Max
            • #51
              f#k these bulgarian folks!!! see MASSIVE BUNCHS OF DETECTORS done in ukrainia!!! ... mlia, effective... I am crying
              • #52
                As always.... are they your punching-bag ? I see...
                So must I presume the ukraine folks will share some schematic of this mass produced beauty? Right ?
                Same as 1266 ??? But why I always read 30cm for 5kopecs ?
                Kind regards,
                Max
                • #53
                  The really interesting stuff is that weight is about the same as my TGS...
                  not so easy find such lightweight stuff from east european countries...
                  I'd like having one of these... seems really good made, robust stuff.
                  Kind regards,
                  Max
                  • #54
                    To kt 315
                    СТЕРВА ЕБАНАЯ
                    • #55
                      стерва ебаная
                      kt315 все още не е разбрал, че българите сме добри и в секса Ако дойде на гости в БГ току-виж се почувства "обиден". Не беше ли той изгоненият от md4u.ru? Май ще трябва да му го припомним
                      • #56
                        to kt315
                        copy:f#k these bulgarian folks!!!
                        Таким способом можно говорить только для тебя и твоего пьяного дурацкого народа.
                        сашо
                        • #57
                          Anatoli, Anatoli - kt315, you forget that this forum is visited from many Bulgarians who also visit the russian forums Did you forget that a year ago you were kick out of one of the most visited technical forums in the world? From md4u.ru? Interesting why? Interesting why some of the most respected people who visit md4u.ru, don't want to write in your forum?
                          ПЁТР) Много ли водки пьют русские ?
                          БОРИС) Да, но они не напиваются.
                          ПЁТР) Как ? Никогда ?
                          БОРИС) О, иногда.
                          Но пьяных в России не очень уважают. Но все-таки есть русская пословица: Пьяный проснётся; но дурак никогда.
                          Peter) Do the Russians drink much vodka ?
                          Boris) Yes, but they don't get drunk.
                          Peter) What, never ?
                          Boris) Oh, sometimes.
                          But they haven't much respect for drunkards in Russia. Nevertheless, there's a Russian saying:
                          The drunkard will wake up; the fool, never.
                          • #58
                            Originally posted by sascho.bg View Post
                            to kt315
                            сашо
                            bomb all around. kill them all.
                            • #59
                              brrrr. what you say buddy. you have been foolished. yes, these pirates captured the forum. maybe they did want use forum as market for their detectors. I do not know. this is not interesting me more. I with people did new place free from the spamers and the flooders.
                              if they do not want to write - IT IS THEIR RIGHT. HOLY RIGHT, BTW. or maybe they has not good information for sharing. if they has the info I will see that HERE, ok? I did always look md4u ONLY as the extension of Geotech, not more than.
                              • #60
                                drunkness...
                                Who mixed sex with goodwill here ???
                                You guys drink too much vodka !
                                I think it's time to return to stay on topic... FISHER 1266...
                                Kind regards,
                                Max
