hi.need us patent 141109 whites.
  • hi.need us patent 141109 whites.
    please help.i need us patent 141109 whites. or discovery metal detector.thanks all
    No, can't be this number, this is very old!
      Use Google Patents and find MD patents.
      http://www.google.com/patents
        thank you esteban
        thank you.esteban.
          Hello unregistered !! Did you find your Patent ???? If not , can you double check the patent number , it seems that the detector you are looking for is Pre-1975. Please double check your numbers , and let us know......... Have you checked the other Thunting/Geotech site ?? There is a bunch of U.S. Patents found under the metal detector heading................Eugene
            HI AMTECH2005.thanks....
            Did not find us patent.i need patent 4345528 or 141109 whites metal detector. i need patent whites tm800 automatic. but not found patent whites tm800.
              Your not going to find the Model number on the pat. Just the Tech.
                hi.
                THANKS HOMEFIRE can you send the tech for me?WHITES TM800 OR TM600
                  I have no Idea what patents are used in it , do you?
