Tarsos detector vlf turkey
    Hi Ismail.
    Can you please help us with coils data, like, inductance, resistance of TX and RX coils.
    I also don´t understand what it means that TX coils has 135 turns , plus 12 turns. Is there any picture or scketch of how to make the turns?
    I also had view the test video, wich shows good performance. What about test on the field?
    Finally i saw that this detector can be made to work like a two box, so please let us know that too.
    In advance, many thanks
    Nelson
    Originally posted by ismail surek View Post
    Hİ to all friends and nelson
    tarsos is made in turksh by emekli amca
    this vlf detector is work at 15,4 khz
    Tx and Rx coil diameter 18cm but setting DD coil total diametre is about 24cm
    Tx coil = 136 turn + 12 turn = 148 turn
    after you can test with osicilascope to coil. It should be about 130v
    osc 12turn if 12V 136/12=11,33 , 11,33x12=135,96V
    And Rx coils sinus Vpp:
    Rx coils acord condansator 6n8
    Tx coils acord condansator 10n ( there is must to 60V between the 10n's base)
    and at 1&3 pin but this acord condansators must to be in coils connection pcb at coilboard
    in this picture there is 1k Resistor but this is pull out after setting coil.(it is for easy setting)
    but screening Tx coil with aluminium gelatine full envirions and shield to ground
    setting coil:
    At first turn right end 22K pot
    approach toeach other coil come to dead point.This is DİSC.
    if you turn the pot left -right but no sound turn oposite to 22K slowly and set the disc
    you have to hear of tarsos sound
    after silent to sound with disc pot and doing fine tune of sound with G.E.B
      hi nelson and all friends
      tarsos Rx and Tx 18 cm diameter coil wire 0,30mm
      tx coil The initial this one and 12 turn Wrap two Go on
      136 turn wrap finish number three
      rx coil start turn this one 157 turn wrap finish number two and
      without the gap in foil turn..
      best regards
      night...
        hi friends
        you can understand easily in this picture english format ( new )
        best regards
          Thank-You Ismail Surek for posting this simple schematic . 2cm coin @ 35 cm !! The dirt in turkey must be perfect soil , no mineralization ? Hopefully others from all over , will soon post more field tests .....Thanks again........Eugene
            Hi Ismail.
            Here i m sending Tarsos on sprint layout format.
            If you see i have replace the jumper by another track, so please if anyone can check if this is ok, just let us know.
            Nelson
            hi friends
            best regards
              hi nelson
              my check your sprint layot good job tanks
              http://www.savefile.com/files/1788168
              night....
                correct pcb....
                http://www.savefile.com/files/1788269
                  hi all friends
                  look working one tarsos project
                  Interesting test video more this link http://video.google.com/videoplay?docid=7847131691300608980&ei=JwPaSLq1BYe uiAKEhomgCw&q=tarsos
                  Owner H.dalcı tanks
                  project design by Emekli Amca tanks
                  best regards
                  night...
                    Sorry guys,
                    I want practice my turkish:
                    Çok harika olmuş. Tebrik ederim.
                    Selamlar,
                    Aziz
                    Originally posted by night View Post
                    hi all friends
                    Owner H.dalcı tanks
                    best regards
                    night...
                      Hi Night.
                      Excellent video about tarsos performance. Very good and the best of all, it looks very easy project to do, simple parts and not to much parts to mount.
                      This will be my next project.
                      Nelson
                      hi all friends
                      Owner H.dalcı tanks
                      best regards
                      night...
                        Originally posted by nelson View Post
                        Hi Night.
                        Nelson
                        tarsos project it looks very easy project and good performance In the middle the result
                        best regads
                        night...
                          hello
                          This morning perform detector pcb tarsos and I spent the afternoon putting the components.
                          A meeting incognita to me because in the scheme i see the configuration and pcb it is alterate. Specifically in the lm324 between pines 5, 6 and 7 pins are altered components. between pines 6 and 7 the preset is 470k, between pines 5 and 7 the R is100K; between pines 5 and 1 the R is 100K and between pines 6 and pin 1 the c is10nF. Is this correct?. The pcb is correct?.
                          Thank you
                          Carlos
                          hola a todos
                          hoy por la mañana realice el pcb del detector tarsos y por la tarde me dedique a colocar los componentes. Me encuentro con una incognita ya que en esquema aparece una configuracion y en el pcb otra. Concretamente en el lm324 entre los pines 5,6 y 7 estan alterados los componentes. Entre el pin 6 y 7 el preset es 470K, entre el pin 5 y 7 la R es 100K, entre pin 5 y 1 la R es 100K, entre pin 6 y 1 el condensador es 10nF. Es esto correcto?. el pcb es correcto?.
                          Gracias
                          Carlos
                            that site in the web i can open a Turkish translator online English to see the site where it explained the detector tarsos?
                            Thank you
                            Carlos
                              Wire
                              Good project.....!!!
                              Explain wire connection from pcb to coil ? 4 wire + ground or ?
                                The pcb is correct and the last schematic the friends are changed the pins numbers
                                Carlos
