Tarsos detector vlf turkey
  • #91
    Return to the fantasy-new version of old song.
    Turk is the composer. Working detector can not be done by people without experience.
    • #92
      hello dfbowers
      ı m congratulations you for auto tune mods very useful work s
      10nf and 6n8 not unchangeable value,try diffrent value obtain high efficiency of rx,tx(pure sinus and high amplitude)
      unregistred pipi.... tarsos very easy and working project try it...look..
      http://video.google.com/videoplay?do...23956765236493
      • #93
        Is not possible to GND balance work and diskriminirane.There is 90 degrees difference in phase.
        • #94
          Is not possible to GND balance work and discriminate.There is 90 degrees difference in phase.
          • #95
            TARSOS,answer me.
            Will tell you how it is possible
            simultaneous work with ground balance and discrimination?Please, do not mislead naive people.
            • #96
              TARSOS,answer me.
              Please say how it is possible
              • #97
                Ground balance and discrimination
                Pipi,
                I think that if you read the forum, people have pointed out that the original Tarsos design is good, but not when it comes to working in the ground. The whole point of the autotune option is to help filter out the ground but does not completely eliminate it.
                MAYBE instead of wasting your time telling everyone that they cannot, you should contribute and show us all how to do it BETTER! That is the point of sharing!!
                Don
                • #98
                  it is elementary
                  dfbowers,
                  Use two channels -GND and DISCR.Should be used for reciver and transmission circuits with small L and large C.
                  • #99
                    Hi pipi,
                    Instead of posting as a guest, why don't you register?
                    Others are more likely to answer your questions if you are a registered member. There is no reason not to register - it's FREE!
                    • There is no competent people to answer.I should not have to indicate errors in the basic scheme.
                      • Originally posted by pipi View Post
                        It's more likely that no-one is answering because you're not registered.
                        Anyway, it's your choice.
                        • Koji je tvoj problem pipi
                          • Pozdrav. Sastavio sam stampanu plocicu ovog detektora pa dok ne nabavim zicu moze li mi neko dostaviti informaciju ko je napravio da li je stabilan i vrijedi li se pomuciti oko njega.
                            • Dino pozdrav,
                              ne vredi, obicna igracka. Radi, zaista radi ali je neupotrebljiv na zemlji. Doabr je samo u edukativne svrhe. Previse se digla halabuka oko prostog i neozbiljnog projekta.
                              Zivio
                              • Не е играчка има голяма мощност в ''TX'' около 25 волта , има и дискриминация за металите.
