HI ALL
  • HI ALL
    please give me real shematic lrl (gold.silver.cave)mode.pleas give me shematic.for exampel thomas model 301 or graviator thanks all.pleas i needed shematic LRL.(gold.silver.cave)mode.thanks all firendes
    Electroscope 301 ?
    http://geotech.thunting.com/cgi-bin/...e301/index.dat
    Be warned, its very likely a waste of Time.
    As far as i know, none of these LRLs work.
    Good Luck
      thanks but...
      thanks but i need a really shematic LRL.working really.(GOLD.SILVER.CAVE) i need a really shematic lrl working.
        You won't find one here!
        Try the Remote Sensing Forum. There are some schematics there (not claimed to work though) and others in the LRL projects section.
          Very simple and easy way to excellent home-made LRL.
          http://www.metacafe.com/watch/940341...etal_detector/
          Noting: pull out antenna to really deep search!
            This is not an LRL.
              You must know how to use it!
              This is not an LRL.
              How do you know?
              This is the best LRL existing, the best LRL ever, on properly use, of course.
                HI.WM6
                HELLO.WM6. VERY VERY THANKS FOR YOU.please give me shematic lrl.i hope made the best lrl please give me shematic.very very thanks.
                  gold does the people crazy
                    REAL (cough, cough) LRL (splutter, splutter)
                    NO SUCH THING MATEY.
                    Get a couple of copper (or brass) divining rods. They'll do better. I've HEARD that Aluminium ones absorb the photo-striatic ions better though, and thus have a better preponderance to indicate the bovine feacal matter in the subject area of LRL's .
                      There is no schematic, dear David, just put together two things (as you can see on video - be careful on right angle and delay between both unit) pull out antenna, do multiple deep inhale, and go to gold mining. For better results prospector have to be properly grounded, but its simple to do, you need only to walk around barefooted. Just suggestion: if you can, use SW radio coupled with SW (or at lest CB) quad antenna. Good luck!
                        hello.dear wm6...
                        hello.dear wm6 very thanks full.for information.i just my lovely whites tm808.it is a very very perfect.and very good system for found the treasure.in deeping.i need a very good LRL
                        but noproblem.becuse i have a two whites tm808. tm808 new and tm808 old(cave mod) i found the very rilck.and one treasure.my lovely just whites tm808.very thanks.wm6
                          How do you know?
                          Abandon all hope, ye who enter here.
                            You do not need to enter in soil, Qiaozhi, as this is very long distance sensor. But probably you are too much theorizer, "One gram of practice is worth more than a ton of theory", you know?
                              Exactly!
                              Instead surfing & listing Wikipedia and repeating trivial theories from there, some people better to start working real electronics, for a change.
                              But who am i to judge anybody?
                              Yes WM6 you are right!
                              Cheers!
