There are no errors in the places you specify. Pay attention to the polarity of the power supply.
DEEPERS
Hi all, the deepers 8 schematics work and it have good dept, I had make and used, the problem is calibrating process is little complicated if you don't know the deepers details, see the deepers 10DD posted by me its almost the same design, if somebody detect an error in deepers 8at please post details here.
thanks
Hi sbalio1 the deepers version is deepers 8 at, not deepers x8, the scheme of deepers 8at work because I built two units and they work. I am working in deepers X5 and deepers 10 DD, now the version 10 is working and soon I will post pictures and scheme updates.
take care
Originally posted by MFC View PostThe deepers X8 dont exist, deepers are Deepers 8at and Deepers X5
Versions are
Deepers 7
Deepers 8at
Deepers 10DD
Deepers prospector
Deepers MF
Deepers 2x1
Deepers X5
Deepers MaxiDetect (last model)
I put schemes for 10 DD, 7 and X5.
Bed zatvor curent 5mA = irf740 !
Pustareka, can you share LTspice asc file, to check what are the timing of detector
For me this detector has following disadvantages:
- no 2-nd sample to cancel magnetic field (as it is in SD2000)
- no 2-nd channel to cancel ground ministration (as it is in SD2000)
- fake discrimination ability.
Device can be used only on non-mineralized soils.
Originally posted by flex View PostPustareka, can you share LTspice asc file, to check what are the timing of detector
PCB SD2000 ?
Deeper 10 vremenaya diagramma.asc
Deeper 10 vremenaya diagramma.rar
Deeper 10 Gold.asc
Deeper 10 vremenaya diagramma v6.rar
Ok deepers don't have ground balance, but in Cuba exist a red ground in my town that I doubt fully that these minlab sd2000 detectors work. The extreme mineralization level is hard to pass, Most dept lost for any detector. Its a physics problem. The very high conductive terrain. Ok the deepers have not any ground balance but if the terrain permit prospecting it have very good dept, maybe more than 1.5 mts with the frame 1x1m very easy. For the deeper you most use less sensitivity using pot sensi, and after balance and adjust. You must familiarize with any detector if not you will never use efficiently. Other thing, deeper circuit is more easy to do.
